Interior/Exterior Headliner DIY
Old 05-01-2016, 03:49 PM
daviday's Avatar
daviday
daviday is offline
Originally Posted by bratling
That looks fantastic! What kind of fabric did you use and where did you get it? From that last pic it looks like something with a suede-like nap.
Thank you. I'm pretty happy with how it came out. The fabric is suede headliner from www.yourautotrim.com. I also bought the fabric with out the backing for the little box towards the rear of the car that houses the sensor.
  #77
Old 07-01-2016, 12:28 AM
X757XVeritas's Avatar
X757XVeritas
X757XVeritas is offline
Someone did a chop job of re covering the liner in my car before I got it. They cut the edges flat with the liner so it's starting to sag across the front, I think I'm gonna go a different route than you guys and pull all the fabric and foam off and then do a thin layer of fiberglass over the base headliner and paint it a matte colord. Maybe blue to match the seats and carpet. As soon as I install my underdrive pulley, and swap my struts, and a million other tiny things that are bugging me lol.
  #78
Old 07-01-2016, 05:04 AM
daviday's Avatar
daviday
daviday is offline
That could be cool. I'm not very familiar with fiberglass but keep in mind that you have to bend the headliner to get back in. The limited amount of times I've worked with it - it became brittle after curing.
  #79
Old 07-01-2016, 05:11 AM
X757XVeritas
The right kind of glass in a thin layer will have a little bit of flex to it. Since it's not going to be structurally integral at all it won't need to be thick. And it won't ever sag or fade again.
  #80
Old 12-03-2016, 02:38 PM
R6boater's Avatar
R6boater
R6boater is offline
Did my headliner today; allowing my not-so-inner nerd to show...
T.A.R.D.I.S. print fleece.
  #81
Old 12-03-2016, 03:01 PM
daviday's Avatar
daviday
daviday is offline
Amazing. What'd you think of fitting it?
  #82
Old 12-03-2016, 03:30 PM
R6boater's Avatar
R6boater
R6boater is offline
It wasn't bad at all. With the fabric being fleece was easy to work with. I had it laid out on a table in the garage with plenty of room to work around it. I'm tall so I was able to reach around it pretty well. Worked from front to back, had it rolled/folded and worked it down about 6-10 inches at a time.
I used the black metal "paper clips" to hold the edges down when I wrapped them over.
Biggest PIA was refitting the b-pillars.
  #83
Old 12-04-2016, 09:46 AM
daviday's Avatar
daviday
daviday is offline
Great idea with the black clips. All the pillars are a bit of a pain IMO. You got it done though!
  #84
Old 12-12-2016, 06:28 PM
asylum sound's Avatar
asylum sound
asylum sound is offline
...while replacing the headliner....
I will be replacing the headliner in my '05 MCS this winter.
Two questions for those who have done this before:
- the headliner material at Joann's Fabric is a darker gray. What is the correct, light gray color headliner at yourautotrim.com? Platinum?
- while I have the headliner out, what other improvements or maintenance can I do? For example, is it worth spraying some sound proofing material inside the roof?
Thanks for any tips!
  #85
Old 12-13-2016, 07:22 PM
Mini Mania's Avatar
Mini Mania is offline
Headliner
Looks great, Daviday! It provides a whole different perspective on traveling.
Would love to see the look on the faces of people sitting in the back seat for the first time.
  #86
Old 09-14-2017, 12:12 AM
volki
volki is offline
I'm so glad I found this DIY thread. The headliner on my 03 R53 is in bad shape. Although it looks to be a bit more involved than I would have liked, but I'm ready after seeing all the great outcomes here.
Just a few questions:
- Seems like 58'' x 108'' headliner fabric I found online would fit. Although I don't mind extras, is the width (58") going to leave enough extras for the sides. Do I need extras on the sides (to be folded)?
- I ordered a can of 3M 38808 Headliner and Fabric Adhesive (18.1 oz.). Given that my car has a sunroof, I assume I would not need a second can.
- Any suggestions for a metal brush to get rid of the old foam, or would anything with rigid bristles do?
Thanks!
  #87
Old 09-14-2017, 06:35 PM
daviday's Avatar
daviday
daviday is offline
Thanks!
I just looked back at what I ordered - exactly that. I would, however, get two cans of adhesive if you're ordering it. I don't have a sunroof and used every bit of two cans. Probably could of used a touch more to be honest. As for the brush - anything with rigid bristles will do.
Good luck - Take your time and post pics.
  #88
Old 10-08-2017, 02:47 PM
volki
volki is offline
The Phase I of the project is completed!
Everything went fine with the removal of the parts. Taking the headliner out was a bit scary because it tends to bend in the middle where there isn't much support between two sunroof holes + dome lamp.
Gotta come up with a plan to place the new headliner wrinkle free while working with those two big holes in the middle.
Will post more during and after the project is completed.
  #89
Old 10-08-2017, 04:21 PM
RllyDrvrIX's Avatar
RllyDrvrIX
RllyDrvrIX is offline
Congratulations!
Patience is rewarded!
  #90
Old 02-17-2018, 07:06 PM
RedAggie03's Avatar
RedAggie03
RedAggie03 is offline
Should I use some 3M adhesive remover to clean this mess up? It’s a nasty goo...
  #91
Old 02-18-2018, 05:11 AM
daviday's Avatar
daviday
daviday is offline
No need! Just rub it with your hands til it comes off. I feel like adhesive remover may actually make more of a mess.
  #92
Old 02-18-2018, 06:56 AM
SebZMonsteR's Avatar
SebZMonsteR
SebZMonsteR is offline
I've used metal wire brushes & a metal wire broom (at different times for different cars) in the past to get the old padding and adhesive off & it worked great! You obviously don't want to be too harsh on it, but it works really well and quickly. Good luck!
  #93
Old 02-27-2018, 12:24 PM
RedAggie03's Avatar
RedAggie03
I ended up using a knuckle brush which worked much better than a plastic scraper. Followed by acetone and a rag which worked VERY well in the final cleanup / prep process.
...a knuckle brush is something like this:
  #94
Old 02-27-2018, 12:49 PM
SebZMonsteR
Awesome!! Be sure to share a picture of it when you're all done
  #95
Old 11-10-2018, 04:39 PM
shrevemini's Avatar
shrevemini
shrevemini is offline
Will be doing this to my 04 mini I just purchased.
  #96
Old 12-17-2018, 08:12 PM
shrevemini's Avatar
shrevemini
I did mine this past weekend. I found using a wide an small putty knives worked great to remove the yellowed old foam. Just rolls off. Then used a small brush for the area I could not reach. Came out awesome. Only issue I had was my left rear pillar panel broke one of the clip anchors off. So I had to order a replacement.
  #97
Old 12-23-2018, 01:39 PM
shrevemini's Avatar
shrevemini
Completed headliner install.
  #98
Old 05-25-2019, 05:48 PM
kkcshipp's Avatar
kkcshipp
kkcshipp is offline
What is the secret to getting the B pillars back in? Everything else went as described but I can't get them to snap back in.
  #99
Old 05-25-2019, 05:56 PM
shrevemini's Avatar
shrevemini
Make sure the prongs are bent out to grab the body. I replaced a couple of mine when they broke off durring removal.
  #100
Old 10-02-2019, 05:44 PM
golden_child's Avatar
golden_child
golden_child is offline
Coordinator :: Capital Area MINI Modders
Any tricks to not breaking the A-pillar?
Quick Reply: Interior/Exterior Headliner DIY
