How To Suspension :: Springs Install How-To
Old 01-08-2013, 10:40 AM
HotRodPontiac's Avatar
HotRodPontiac
HotRodPontiac is offline
I figured as much, thanks for the info!
  #127
Old 01-11-2013, 01:46 PM
NC TRACKRAT's Avatar
NC TRACKRAT
NC TRACKRAT is offline
Tip: Especially when camber plate assemblies are involved, you may run into a clearance problem when removing and installing the RH side spring/strut assembly, even after compressing the spring. Don't fight it! Just take out enough of the plastic inserts and the two sheet metal screws from your wheel well liner so that you can deflect it, allowing the strut to clear. Five minutes will save you a bunch of stress.
  #128
Old 02-19-2013, 11:13 AM
littlehandegan's Avatar
littlehandegan
littlehandegan is offline
Coordinator :: Low Country MINIs
Pictures all dont work?
  #129
Old 04-13-2013, 04:03 PM
07R56MINI's Avatar
07R56MINI
07R56MINI is offline
Anyone know why pictures don't display?
Info would be great if I could have a visual.....
  #130
Old 04-13-2013, 04:51 PM
Eddie07S's Avatar
Eddie07S
Eddie07S is offline
Received 1,136 Likes on 891 Posts
More than likely the OP ran out of room for the pictures and deleted them... just a guess.
  #131
Old 04-14-2013, 06:45 AM
07R56MINI's Avatar
07R56MINI
Anyone know of any other write ups that may have pictures?
  #132
Old 04-22-2013, 12:26 PM
XXLil MickXX's Avatar
XXLil MickXX
XXLil MickXX is offline
  #133
Old 02-02-2014, 12:44 PM
ageofoctane's Avatar
ageofoctane
ageofoctane is offline
Originally Posted by k-huevo
Assuming the pinch bolt removed was for the steering knuckle’s grasp on the lower end of the strut and not the sway bar drop link; as justintime mentioned, spread the gap at the base of the strut. There is a suspension spreader tool made for this task, but the square end of a ¼ inch drive extension will also do the job.
Place the extension into the slot from below and twist 45 degrees.
Thank you for this tip! (I know it was years ago now, but it saved my night last night). I wound up with a broken pinch bolt that I had to drill out, and an outer ball joint that would not come out of the wheel housing. I was eventually able to separate it from the control arm instead using a pneumatic pickle fork, but during reassembly, I was having a REALLY difficult time fitting the the new strut into the wheel housing. Your advice on using a 1/4" ratchet saved the day.
I was expecting to get both front struts changed out in 4 hours or so, but with all of the setbacks doing the drivers side this weekend, I have to save the passenger side for next weekend. Next time I'll try using an impact wrench to remove the pinch bolt instead of the appropriately named "breaker bar". And I'll be spraying pb blaster on all of those tough nuts and bolts a week in advance.
  #134
Old 05-29-2014, 10:05 AM
b0rderman's Avatar
b0rderman
b0rderman is offline
Hate to bump this thread again, but I am in a pinch. My rear struts have given up on me and I need to get them swapped out with Koni yellows. Does anyone have a lead on a good rear swap tutorial with pictures? Will need to purchase or rent the spring compressor...and perhaps the specialty 21mm strut socket as well, if necessary.
The rear swap seems fairly straight forward, with just a couple simple drill-outs on that washer and the hat. My main concern is the spring replacement with the spring compressor, but I'd imagine any generic youtube tutorial will suffice there.
Also, I know it is not ideal, but for now I would like to just replace the rears to get me going again. Any thoughts on mixing stock front struts with koni yellow rears for the time being? All four struts would have H-Sport springs installed on them.
Again, sorry for the topper here, but I am about to dive in and would love all the visual support I can get.
Stefan
  #135
Old 12-08-2014, 06:31 PM
Lex2008's Avatar
Lex2008
Lex2008 is offline
  #136
Old 12-15-2016, 08:20 AM
r2mini's Avatar
r2mini
r2mini is offline
I know this is an old thread, but I recently found these videos by KYB that are super helpful (of course after learning the hard way) -
  #137
Old 12-15-2016, 09:55 AM
Lex2008's Avatar
Lex2008
Lex2008 is offline
Thanks for the videos. Im sure they will help folks out.
What I wanna know is if the regular R56 cooper springs will fit my R56 cooper S. Im tired of that pounding ride. Its atrocious.
  #138
Old 12-16-2016, 05:56 AM
Eddie07S's Avatar
Eddie07S
Eddie07S is offline
The springs are interchangeable but that won't be overly helpful if you are on the stock shocks. I recently found out how much of an improvement new shocks will make in the car's ride. I have the optional sports suspension and put on a set Bilstein Sports shocks (supposedly even stiffer than what I had) and they made my run flat tires tolerable. We also have a base Cooper with the stock shocks and its ride has some harness that I am sure will disappear once the new FSDs go on.
  #139
Old 12-16-2016, 05:58 AM
r2mini's Avatar
r2mini
r2mini is offline
What Bilsteins did you buy? I bought the B4s and I had to return them as there was a flang that held one of the brake lines preventing the strut from going all way the way down to attached the spindle bolt. I did buy the rears, installing those and my other three springs this weekend.
  #140
Old 12-16-2016, 08:25 AM
Eddie07S's Avatar
Eddie07S
Eddie07S is offline
I have the B8s. The thing I found was that they took out that sharp, harshness that you get going over ridges or ridge like things in the road, making the ride much more tolerable. Note, I have stiffer springs than you and really big sway bars front and rear. So saying that the ride is now tolerable is saying something - IMO.
Sorry to hear about the B4s you got. There is a great B4 vs FSD thread hear on NAM and people are generally very pleased with the B4s. Bu,t then again, every once and a while there will be a post about something being wrong with one of the shocks in a set a person bought. So it happens. Hope yours gets worked out ok.
  #141
Old 12-16-2016, 09:20 AM
Lex2008's Avatar
Lex2008
Lex2008 is offline
I put in FSDs, all new bushings front and rear and yes the FSDs help but the ride is still obscene. I have race coilovers and thick sway bars on another vehicle and it rides only slightly harsher than the Mini with FSDs. Those runflats are like concrete.
So youre saying that putting on non-S springs wouldn't help much?
  #142
Old 12-16-2016, 10:43 AM
Eddie07S's Avatar
Eddie07S
Eddie07S is offline
No, only that if you were on the stock shocks, the springs won't help much. You have FSDs now, so the base Cooper springs should help further. Just reminder, the softer springs will drop the handling down a notch, not much but a little.
Another option to think about is wheels/tires. What size are you on? I run the 16" wheels with the stock tire size. This is far better that 17" tire/wheels. As for tires, the Continental DWS has a far better ride than the OEM RFTs, but some people think the sidewalls are too soft on those. Just some thoughts.
  #143
Old 12-16-2016, 11:06 AM
Lex2008's Avatar
Lex2008
Lex2008 is offline
ah...thats good to know! Ok so I can buy some used non-turbo r56 cooper springs and they will fit? I assume the car will sit a little higher as well, yes?
I have Conti DSWs on a car....yes the sidewalls are soft like wet tissue paper. I think Michelins have a much better ride. The runflats are obscene but they have tons of tread on them so I cant justify getting rid of them yet.
Im running 17s? 18s? Its my girl's daily driver, so I cant go and check.
  #144
Old 12-17-2016, 05:42 AM
Eddie07S's Avatar
Eddie07S
Eddie07S is offline
The S and non-S springs will give the same ride height (only the red JCW springs lower the car).
Have you tried raising the tire pressure on the DWS tires to stiffen the sidewall? Some people have found increasing the pressure by 2 or 3 psi helps.
Likewise, have you tried lowering the tire pressure on the RFTs by 2 or 3 psi to improve the ride?
  #145
Old 12-18-2016, 05:13 AM
cristo's Avatar
cristo
cristo is offline
Alliance Member
There are actually 6 different springs for a non-S, and 6 different ones for
an S (3 front and 3 rear). This is based on info for the R50 and R53, I'm
assuming this holds for later models as well.
The springs are selected to keep ride height the same based on weight of the spec'd car,
so if you put non-S springs on an S, it will actually ride a little bit lower, especially in
the front. Other factors like sunroof, etc. also enter into the equation (springs selected
for a non-S with a sunroof and other heavy stuff will ride higher than springs selected
for a non-S without that stuff if installed on the same MINI).
  #146
Old 12-18-2016, 05:45 AM
Eddie07S's Avatar
Eddie07S
Eddie07S is offline
What he said...
  #147
Old 12-20-2016, 02:44 PM
Lex2008's Avatar
Lex2008
Lex2008 is offline
Yes on both and yes it helps.
  #148
Old 12-20-2016, 02:47 PM
Lex2008's Avatar
Lex2008
Lex2008 is offline
Good info! I was hoping to get some used non-S springs for an R56 but this makes it more complicated for sure.
Im so sorry for buggering up your R50 thread guys. I didnt realize I was in a gen1 forum.
Ryephile
Suspension
113
02-09-2020 03:43 PM
adrchn
08-13-2019 02:11 AM
squawSkiBum
10-02-2015 09:21 AM
Emnotek
08-13-2015 05:47 PM
Quick Reply: How To Suspension :: Springs Install How-To
