How To READ BEFORE POSTING How-To forum purpose and requests
Old 01-14-2011, 10:27 AM
Motor On's Avatar
Motor On
Motor On is offline
The How To forum is a place for threads dedicated to explaining how to accomplish, tweak or modify something on your Countryman.
If there's something that you don't see a thread for in the How To forum, please post a request for it in this thread so others can check it and make it if possible. Do not start a new thread asking for a how to for something, so that when people see a thread with a particular subject they'll know that it will contain directions from the get go.
Also please note to make sure this format is maintained; all new threads in this forum do require moderator approval before the display in the forum.
Old 03-10-2011, 04:03 PM
chessie1629
chessie1629 is offline
oil change
How do you change the oil filter without spilling oil everywhere?
Old 03-17-2011, 10:45 AM
03mini-S's Avatar
03mini-S
03mini-S is offline
Remove the oil pan plug to start draining then loosen the filter case but don't remove it. Leave it on by the last thread or so. This will allow air to be drawn in and pull the oil down into the engine.
Old 03-20-2011, 06:59 PM
Longley01's Avatar
Longley01
Longley01 is offline
Oil Change -- 4 questions:
1. Quanity--is it same as Gen II guys 4.4 quarts?
2. Torques -- same as Gen II guys as well?
Oil pan drain plug = 22.0 lbs/ft
Oil filter cap = 18.5 lbs/ft
3. Has anyone used / have experience with oils from http://www.renewablelube.com/motoroilsHP.htm ?
4. Has anyone found a good service manual for the Countryman?
As always, thanks for the help!
Old 06-13-2011, 04:44 PM
JoniF's Avatar
JoniF
JoniF is offline
Has anyone changed out their sidescuttles? I just got mine in and doesn't have clear directions. I'm hoping I can install this myself and not have to pay at the shop.
Old 06-18-2011, 09:44 AM
dogmasue's Avatar
dogmasue
dogmasue is offline
Does anyone know how to remove the SPLIT REAR CENTER RAIL? (see photo)
I need to remove it in order to create a lower platform for my Dog crating and I don't know where to begin
TIA!
Old 06-18-2011, 07:46 PM
dogmasue's Avatar
dogmasue
dogmasue is offline
i figured it out
once i slid the rubber insert towards the front of the car, it exposed the first screw head. it was all downhill after that!
(or should i say about a dozen screw heads downhill after that!)
Old 06-23-2011, 10:05 AM
Newdl's Avatar
Newdl
Newdl is offline
Dogmasue,
I am sorry I did not see this sooner...I look mine out this past weekend. I am also having a center fill piece made in the Kent area by an interior shop that I know and trust. This will fit between the two existing seats and create a bench style seat.
Interested?
P.S. I didn't remove my rear seats to pull my rail out... That must have been a ton of work!!!
-Newdl AKA Neal, your MINI Motoring Advisor
Old 06-23-2011, 08:28 PM
dogmasue's Avatar
dogmasue
dogmasue is offline
hey neal! you are popping up everywhere!
chris took the back seats out (for good, not just for the center rail removal) -- they didn't seem to be a problem.
i'll be installing custom dog crating in the rear seat area as soon as i get them designed and ordered. for now, this will have to do, but it is only good for one dog:
Old 11-25-2011, 03:54 PM
northbarts's Avatar
northbarts
northbarts is offline
Does anyone have tips for changing the motor oil in my 2002 Mini? I,m doing the service this time instead of the shop this time around.
Old 11-26-2011, 07:10 AM
chrunck's Avatar
chrunck
chrunck is offline
You're in the Countryman section of the forums, so you're not going to find anything here. What you want is the 1st Generation how-to forum here: https://www.northamericanmotoring.co...ms/how-to-340/
Old 03-04-2012, 12:29 PM
rfath's Avatar
rfath
rfath is offline
Request: dash take-apart for wiring iphone mount?
I'm a lemur and didn't get the armrest/iphone snap-in. I DO have the cravenspeed mount and an extra-long extender cable and a need to thoroughly frustrate myself, apparently.
Does anyone have any hints for dash pull-apart to run the extender inside?
Old 08-05-2012, 04:21 PM
Weare138's Avatar
Weare138
Weare138 is offline
Has anyone changed their brake ducts? Care to share install tips?
Old 08-24-2012, 04:12 PM
KidLuck's Avatar
KidLuck
KidLuck is offline
anyone have any info on changing the spark plugs?
Old 09-22-2012, 12:50 PM
Hujan's Avatar
Hujan
Hujan is offline
How to request: How to remove lower plastic grill?
How do you remove the lower plastic grille (the one in front of the intercooler)? Ideally, I'm wondering if it can be done without removing the bumper. Thanks!
Old 10-08-2012, 06:23 AM
countryman-s's Avatar
countryman-s
countryman-s is offline
If I remember correctly its part of the front bumper. You would have to cut it out you would have to remove the bumper, and it's a pain in the butt
Old 01-20-2013, 08:22 AM
devinkato's Avatar
devinkato
devinkato is offline
How do you replace headlight bulbs and adjust aiming angle?
Old 02-05-2013, 12:11 PM
iriedevil32's Avatar
iriedevil32
iriedevil32 is offline
How do you remove the side scuttles on the Countryman S?
Old 03-06-2013, 08:28 PM
rayzmini's Avatar
rayzmini
rayzmini is offline
Unhappy how do you change the front turn signal bulb?
Howdo you gain access to change out those ugly orange turn signal bulbs please advise!
Old 03-23-2013, 09:13 AM
Weare138's Avatar
Weare138
Weare138 is offline
How do you pop off the Mickey bezel around the speedo and vents? And also how to pop off the left and right vent pods?
Old 03-23-2013, 09:24 AM
Hujan's Avatar
Hujan
Hujan is offline
https://www.northamericanmotoring.co...dash-trim.html
See post #8.
Old 05-09-2013, 10:48 PM
jakers's Avatar
jakers
jakers is offline
I'd like to post a how-to on trailer wiring. I've searched high and low for good instructions for a 2011 All4, but I haven't found anything comprehensive. I finally got mine working, and I'd like to share what I did in case some other people run into the same stuff I did.
Old 11-04-2013, 12:33 AM
RonkyOne's Avatar
RonkyOne
RonkyOne is offline
My remote control for gate
inserted in the ashtray, which does not use
Attached Thumbnails READ BEFORE POSTING How-To forum purpose and requests-20131101_193000.jpg   READ BEFORE POSTING How-To forum purpose and requests-20131101_190147.jpg   READ BEFORE POSTING How-To forum purpose and requests-20131101_190304.jpg
Old 11-19-2013, 02:05 PM
Big K's Avatar
Big K
Big K is offline
Red face Removing rear light trims
So I had a 07' Cooper and had no problem removing rear light trims, now I own a Countryman and attempted to remove the rear trims and broke some tabs and actually broke the trim at the bottom. If someone could share some pics and useful info on how to remove these would be great!
Old 11-23-2013, 04:14 PM
chrunck's Avatar
chrunck
chrunck is offline
There's a thread here somewhere with directions on removing the rear trim. I'll see if I can find it.
Quick Reply: How To READ BEFORE POSTING How-To forum purpose and requests
