How To Maintenance :: Thermostat Change
Old 01-04-2011, 03:18 PM
Mr. Jimmy's Avatar
Mr. Jimmy
Mr. Jimmy is offline
Has anyone out there done a 2008 Cooper Hatchback?
I am currently dead in the water on mine. Worried about breaking the little plastic zip ties and wiring channels attached to the top of the thermostat housing.
Suggestions anyone?
  #27
Old 01-08-2011, 09:47 PM
Velocious's Avatar
Velocious
Velocious is offline
thanks @thebigf for the guide! I just did the procedure on my r53 and your guide saved me a ton of hassle (not to mention the $350 quoted by the mini dealership). also thanks to @fishbone for the tip about the ecu! I'm crossing my fingers that i'll be leak free from now on!
  #28
Old 02-01-2011, 04:36 PM
kindofblue's Avatar
kindofblue
kindofblue is offline
I replaced mine over the weekend with this great guide. Thought I might add some pictures and my own tips.
1. Definitely just flip up the airbox.
2. For the love of God don't take off the throttle body intake hose: that bottom clamp is nigh impossible to reinstall. I had to go to the hardware store and buy a flathead screw hose clamp, which worked great.
There aren't a lot of photos of where the thermostat is, so I'll add a photo here. This area of leaking I call the Depends Zone:
Maintenance :: Thermostat Change-us1ss.jpg
You can see it immediately to the back of the intercooler cover. If you need to take it off, the bolts are #30 Torx, btw.
Once you're there, you might have the pleasure of seeing this, as I did:
Maintenance :: Thermostat Change-5oxtt.jpg
Sorry for not taking a picture from farther out.
So if you're losing coolant and your expansion tank is as dry as a bone, look to the rear of your intercooler; you can see the thermostat without removing all the pipes or intercooler cover.
I recommend Way Motor Works. Quick shipping. My thermostat (10/05 build) had the stupid white gasket. Now, like Pamela Anderson, it's all silicone in there.
If you don't see that crust, I diagnosed the leak by putting it up on ramps and sliding under. My car looked exactly like the picture on the first page: coolant dripping down the transmission.
  #29
Old 02-10-2011, 11:07 PM
Eric_Rowland's Avatar
Eric_Rowland
Eric_Rowland is offline
Just did this job for a friend. Thanks for all the above info! It was very helpful. Seems weird that the thermostat cover is sandwiched underneath the bracket for the MAP sensor.
  #30
Old 02-12-2011, 06:58 AM
WayMotorWorks's Avatar
WayMotorWorks
WayMotorWorks is offline
Vendor
Ok I see many people complain about the stock clamps on the intake, it's not that hard. They can be snapped back together using simple pliers nothing special. Come see me at the next MINI event your at and we'll show anyone.
HOTCHKIS | DDM | CRAVEN | AKRAPOVIC | NM ENGINEERING | MEGAN | FORGE | IE | OS GIKEN | POWERFLEX and more
  #31
Old 02-12-2011, 09:01 AM
Eric_Rowland
I agree they aren't that bad. Every once in a while they give me fits, but a channel-lock with the top on the 'bump' side of the clamp gets it done. Randy Webb had a pair of 'ignition pliers' (essentially small channel-locks) that worked *perfectly*.
  #32
Old 02-13-2011, 10:20 AM
kindofblue's Avatar
kindofblue
The only clamp I thought was hard was the bottom one on the intake hose; I just couldnt get a good angle with the pliers I have. The rest were easy.
But then, I am the most amateur of shadetree mechanics .
A question: my car didn't have the bolt on the right front corner of the air box bottom; I'm the second owner and it must have gotten lost some time in the past. Should I replace it? If so, does a kind soul know the dimensions of the bolt?
  #33
Old 02-13-2011, 03:35 PM
kazlot's Avatar
kazlot
kazlot is offline
Thermostat Change
I think this is what you want:
6 MM Mounting screw Part#07149146435
From RealOEM.com
http://www.realoem.com/bmw/showparts...79&hg=13&fg=20
Hope this helps...
  #34
Old 03-06-2011, 11:54 AM
Eric_Rowland
Thanks Kazlot - mine's missing too. I think it got lost when my pulley was put on.
  #35
Old 03-07-2011, 07:06 PM
crishchun's Avatar
crishchun
crishchun is offline
Is this the updated thermostat?
I ordered this from rmeuropean.com, I just want to make sure this is the correct updated thermostat. Otherwise I'll return and buy from Way.
Thanks all!
  #36
Old 04-06-2011, 02:36 PM
MiniPilote's Avatar
MiniPilote
MiniPilote is offline
So perhaps this is a stupid question but MUST I USE MINI/BMW antifreeze?
I'm getting ready to do this now.
MiniPilote
  #37
Old 04-07-2011, 01:57 PM
MiniPilote's Avatar
MiniPilote
To answer my own question for anyone else's benefit. No and Yes. No it doesn't need to be MINI/BMW stuff but it does need to meet the requirements of that type. The Bentley Service manual lists it as "phosphate/nitrite free". So YES, it's probably easier to just buy the MINI/BMW brand.
  #38
Old 04-07-2011, 02:34 PM
JIMINNI's Avatar
JIMINNI
JIMINNI is offline
I know this post is a month old, but that looks to be the old style. The new style gasket is clear and looks silicone based.
  #39
Old 04-09-2011, 03:26 PM
fishbone's Avatar
fishbone
fishbone is offline
Valvoline has a compatible coolant. Mini is specifically mentioned as being good for.
  #40
Old 04-09-2011, 08:08 PM
MiniPilote's Avatar
MiniPilote
I completed mine today. I got the thermostat and gasket from Way Motor Works. I didn't bother to remove the air hose to the throttle body, I just worked around it. I had a problem purging the air from the system. I don't think I got it all out yet. Maybe it's because it not quite 40F outside so letting it idle for 30 minutes or so and the fan never did kick on.
I also put the TSW motor mount on. It was much easier than the thermostat.
  #41
Old 04-12-2011, 09:26 PM
nopistons's Avatar
nopistons
nopistons is offline
So do only the S models have a problem with the thermostat gasket or is it the Non-S too? I haven't bothered to look, but i assume the non-S thermostat is in the same place as the S?
  #42
Old 04-12-2011, 10:19 PM
tonester's Avatar
tonester
tonester is offline
I got my coolant from Napa Auto. Zerex G-05
  #43
Old 08-24-2011, 09:02 PM
Rossii's Avatar
Rossii
Rossii is offline
I had my thermostat replaced about 24K ago and 2 1/2 years and now I found a few spots on the driveway. Wiped clean and drove car pretty hard and checked no leak?? I am assuming its the thermostat again. Resovoir is proper level......just curious if the water pump went out what I be seeing?
  #44
Old 10-10-2011, 08:29 PM
jennster's Avatar
jennster
jennster is offline
Are there instructions for the just flipping up the airbox method? I need step by step or at least "start at 1 above and skip 2-6" etc. I would appreciate it immensely if anyone could help. I believe my thermostat is sticking as the temp will redline and then drop suddenly. I don't want to fry my engine. Thanks again. I dig this forum the most.
  #45
Old 10-11-2011, 12:37 AM
Eric_Rowland
Basically, just follow the original instructions omitting the 'remove ECU' (ECM) portions - there are four pictures.
Replace with one step of removing airbox bottom, and rotating it out of the way as in fishbulb's picture in post #13 of this thread. It's all pretty obvious when you get in there.
Might also want to confirm that your fan is working to spec.
  #46
Old 10-16-2011, 04:33 PM
jennster's Avatar
jennster
jennster is offline
Thanks Eric. One more question: Is it generally recommended to replace the housing as well when replacing the thermostat?
  #47
Old 10-16-2011, 08:50 PM
Rossii's Avatar
Rossii
Rossii is offline
Unless its damaged you dont need to replace thermostat housing. Although a shop did add that to an estimate, but not needed.
  #48
Old 10-16-2011, 09:55 PM
Eric_Rowland
+1
The OP replaced the housing, but I can't see doing so unless it is obviously damaged.
  #49
Old 10-17-2011, 12:45 AM
Andrew1400's Avatar
Andrew1400
Andrew1400 is offline
Thanks to the OP of this thread. Did mine this week. No issues and only took a couple hours. Cheers!
  #50
Old 10-18-2011, 03:23 PM
jennster's Avatar
jennster
jennster is offline
Thanks again for a great writeup and the helpful tips all. Can anyone fill me in on what size torx bit is needed. Also, is this what is commonly referred to as a star bit? Thanks!
Quick Reply: How To Maintenance :: Thermostat Change
