How many failed HPFPs? Enough to investigate?
Old 09-11-2016, 07:11 AM
llebcire's Avatar
llebcire
llebcire is offline
Curious as to how many 2011 R60s are needing to have the high pressure fuel pump replaced?
We have a 2011 S All4 and last Wednesday my wife called me to tell me that the check engine light came on when she started it then it went away. Now, the CEL stays on and often accompanied by the light in the tach and limp mode after a cold start. There's also a terrible idle after cold start which fits with reported symptoms and codes indicate misfires across all cylinders along with the dreaded "P0087 Fuel Rail/System Pressure Too Low" which all but confirms the HPFP is failing.
I have a communication in to MINI as this car only has 37,000 miles on it and I'm curious as to what they'll say.
As MINI extended the warranty on previous years HPFP (with BMW recalling them) it feels like this is a concern and possible engineering flaw that could leave someone stranded or in harms way if they are unable to accelerate to avoid an accident. As with anything, if there aren't enough complaints about this then it isn't an issue.
I didn't know if we should start a poll?
Additionally, is there work under way to start an investigation?
Thank you!
Eric
Free read at local auto parts store:
Old 09-11-2016, 09:44 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Minnie.the.Moocher is offline
Our 2011 was done this year at 40k approx, no charge as they extended warranty on it.
Old 09-11-2016, 09:49 AM
llebcire's Avatar
llebcire
llebcire is offline
Countryman?
MINI has extended the warranty on the HPFP assembly? I wasn't aware as everything I read says they only extended through 2010 model year and we don't have a warranty or certification.
Thanks!
-Eric
Old 09-11-2016, 10:08 AM
Minnie.the.Moocher
Yes, Countryman. Ask your dealer to check status for you. Several members have posted in other threads here of 2011s being covered for free.
Old 09-11-2016, 10:29 AM
llebcire's Avatar
llebcire
llebcire is offline
That's awesome and we'll check tomorrow.
Thanks for the update!
-Eric
Old 09-12-2016, 08:17 AM
llebcire's Avatar
llebcire
llebcire is offline
Just got off the phone with MINI of Des Moines - the warranty for the 2011's has been extended and this will be covered at no charge.
Thanks for the advice!!
-Eric
Old 10-02-2016, 07:36 AM
hell0kitty's Avatar
hell0kitty
hell0kitty is offline
I am on HPFP number 4 for my 2012 Countryman. They have all been replaced for free.
y8s (11-15-2017)
Old 10-02-2016, 08:01 AM
llebcire's Avatar
llebcire
llebcire is offline
While it's awesome that BMW is owning this issue it is concerning that they haven't redesigned the pump to prevent future failures.
I can imagine the frustration if this were to happen while on vacation or en route to an important event - the car is driveable but a flashing CEL is never a good sign.
Regards,
Eric
Old 10-02-2016, 08:48 AM
Minnie.the.Moocher
The pump changed in design during 2012 as I recall. Different part number and mfg. I don't know the success of the change.
Old 10-02-2016, 03:27 PM
llebcire's Avatar
llebcire
llebcire is offline
Good to know - thanks for the update!
-Eric
Old 10-02-2016, 03:38 PM
ZippyNH's Avatar
ZippyNH
ZippyNH is offline
People who run their cars low enough to get air in the system (as dangerous to a hp pump as excess water) CAN still kill them....
So I suggest folks avoid running their cars below a 1/4 tank....then again this has been good practice for every car with a fuel pump for years....
Good luck, hopefully the new part # makes this whole ordeal/oddesy a forgotten memory!!
Old 11-18-2016, 01:28 PM
y8s's Avatar
y8s
y8s is offline
My out of warranty 2012 just got a new HPFP this morning. I was going in for maintenance and because I got the reduced power message every day, several times. Finally it was storing codes when I took it in.
The part was in stock and covered under the aforementioned warranty extension on the part.
Took all of an hour for them to do the 40k service and pump work.
Old 11-20-2016, 02:24 PM
cargusjoh's Avatar
cargusjoh
cargusjoh is offline
Does anyone have specific information about what pumps/part number were used in what years, and if one was more reliable than another? I recall this from another post...
Mine is a 2011 R55S so looks like continental.
Ernie Orwig Ernie Orwig is offline
Guys, thanks for the input....
My old motor 2011 had the Continental HPFP and the new replacement 2012 has the Bosch.
The connector for the Volume control is different between the two. I traced them down to different points on the X60231 plug( plugs into the DME ). Luckily I have both of the wiring harnesses. But when I look at the pin out for the DME there is only one reference pin for the Continental and where the Bosch would land, it is a empty pin.
So I am wondering if I needed the DME that came with the Bosch HPFP or will my original work as well?
Any help is greatly appreciated
Ernie Orwig
Old 11-20-2016, 03:19 PM
MannyJimenez's Avatar
MannyJimenez
MannyJimenez is offline
Just replaced my HPFP in my 2011 CMS All4 with just under 49k miles. Mucho no bueno
Old 04-27-2017, 07:44 PM
llebcire's Avatar
llebcire
llebcire is offline
I read about possible issues replacing the battery as well.
About a month ago we replaced the battery (Sam's Club) and haven't had issues. Well, last night we had the car flat bedded for a no start issue but probably not related.
Eric
Old 11-15-2017, 08:17 AM
y8s's Avatar
y8s
y8s is offline
Pump is dying again. Getting the "pressure too low" code in Carly.
high-pressure fuel, plausibility: pressure too low
Code: 002C01
It's been almost exactly a year. Bummer.
llebcire (11-16-2017)
Old 11-15-2017, 08:36 AM
MannyJimenez
Code: 002C01
Dam, do you which HPFP they used?
My local mechanic did not use the OEM HPFP and I’m not sure the brand he used and I’m 13k miles on that HPFP that was replaced on 10/13/2016.
I can ask him if your interested on which one he used
Old 11-15-2017, 01:21 PM
y8s's Avatar
y8s
y8s is offline
Since I was at a MINI dealership, I assume they used the original factory pump. And that's where I'll go to get another one for free.
Old 11-18-2017, 06:29 PM
Pure Red's Avatar
Pure Red
Pure Red is offline
We had ours replaced under CPO warranty at a bit over 40k miles. Intermittent MIL light; loss of power message, the usual warnings . 2012 Countryman S.
The extended pump warranty from MINI would have covered it even if we didn’t have the CPO.
Old 12-20-2017, 08:50 AM
AWD_Rally's Avatar
AWD_Rally
AWD_Rally is offline
Moderator
I think I'm begining to see symptoms.
On cold start it'll be a rough/jerky idle, then be good for basically the rest of the day.
The MINI dealer near me said they basically wont replace it until it fails, or meets specific diagnostics of codes...
Is this true? Or should I try another dealer?
Old 12-20-2017, 09:19 AM
Minnie.the.Moocher
MINI Portland was the same, needed to diagnose and see the correct codes if it wasn't entirely failed. I waited until the code popped up, took it in and they replaced free of charge although I had to agree to pay diagnostic if the pump wasn't at fault.
Old 12-20-2017, 09:43 AM
ECSTuning is online now
Received 1,966 Likes on 1,766 Posts
Yep. 13517592429 was 2011-3/2012,
then they went to the 3/2012 version. 1351860510
8/2010+ Fits the R60/R61 S/SX(All4)/JCW , then you have the
13518605102 for the 3/2012+ R60/R61 S/SX(All4)/JCW
https://www.ecstuning.com/News/MINI_R55_to_R59_High_Pressure_Fuel_Pump_22527/
Old 06-20-2018, 06:59 AM
y8s's Avatar
y8s
y8s is offline
Code: 002C01
Again with the HPFP code last night. Car ran like doo doo after that.
Honestly, they last half as long as an oil change.
Old 06-20-2018, 08:37 AM
downshift1's Avatar
downshift1
downshift1 is offline
I had an Audi 2.0 FSI and had to rebuild the HSFP, what I found when I took it apart was due to the long oil change intervals the oil was sludging up inside the pump and causing it to stick and throw the code.
This may not be relevant, but has someone tried taking one apart to see what's going on or if you may be able to "clean" it?
Old 06-20-2018, 04:17 PM
MrGrumpy's Avatar
MrGrumpy
MrGrumpy is offline
I know the VIN on my ‘12 Countryman says it’s covered under the extension for the HPFP yours should be too. Now if only that turbo warranty extension covered me.......... :-(
Quick Reply: How many failed HPFPs? Enough to investigate?
