Electrical GEN 1 NCS INPA users UNIT!
GEN 1 NCS INPA users UNITE!
Well the search function has changed, or it has on my web browser. Can no longer search by individual forums. Sick of reading Gen2 stuff. I already have everything installed. I'd like to talk with other people that drive the same car I do and compare apples to apples for the most part. So who here is using INPA and NCS Expert and Dummy as well as the other BMW tools on their Gen1?
As you can see, there are not many coders here for R50/R53.
You generally get two sorts of posts, those who can't be bothered to Google a DIY thread and want to be told what to do; and those with technical questions on errors that no one has encountered before.
For the latter, I go here to post threads that don't get answered.
http://www.bmwcoding.com/forumdisplay.php?50-Rxx
I have them installed and have done a few small things. The latest being I had to erase the srs light from my cluster using inpa. I would like to do more with ncs expert. At them moment I cant really decide what I feel is worth spending the time to recode as I am generally pretty pleased with the r53.
I'm coding my 2002 R53. I'm using a usb-obd2 cable and an VM with XPsp2 on my MacBook Pro.
Using Inpa, NCS Expert and, really great, NCS Expert Dummy.
I've enabled a lot of features, like window-auto-up on both sides, comfort open and close with my remote and key, auto-lock at 10mph, auto-unlock when killing engine, Pathway lighting for 60sec ( is to long imo), digital speedo on my BC, and then some. I change my usage indicator from L/100km to km/L ( can also be mpg off course)
also, is a nice feature I think, disable airco at full throttle for these extra HP's when accelerating.
I'm working out now to enable the lights when the wipers are engaged. I believe this can be done with the dipped beam or with the fog lights. don't know what to do yet. as an alternative maybe I'll enable daylight driving lights again, this is also possible.
Furthermore, it is possible to enable/disable the seatbelt warnings. Also,I have enabled the sound alarm for low gas.
what's also nice, for the tuners among us, you can change the redzone on the rev counter to begin earlier or later. there are segments which you can enable so they show up lighted.
Also, I can enable the factory alarm and all its options. Then you only have to built in the wiper-stalk with the red light at the steering column, the siren and the ultrasonic sensors. I already have an after-fit alarm so won't use this option myself, but it's possible.
Anyway, I'm still investigating a lot of options.
For instance, who can tell me what
WINDOW_INCH_AUTO
WINDOW_SHORT_DRIVER and PASS
WINDOWS_SHORT_RAISE_DELAY
and
MISLOCK_BEEP_ENABLE
can do for me?
These are functions of the BC1 Body and Lights.
Anyways, I'm happily coding my R53 1st gen and would like to "unite"
Greetings from the not so cold Netherlands!
WINDOW_INCH_AUTO
and
MISLOCK_BEEP_ENABLE
can do for me?
WINDOW_INCH_AUTO
and
MISLOCK_BEEP_ENABLE
can do for me?
WINDOW_INCH_AUTO
and
MISLOCK_BEEP_ENABLE
can do for me?
here's my BC1.C03:
https://skydrive.live.com/redir?resi...nt=file%2c.txt
DWA
nicht_aktiv
VERRIEGELN_AUT_AB_X_KM/H
aktiv
ZV_SELEKTIV
nicht_aktiv
STANDRUECKSCHALTUNG
aktiv
VERRIEGELUNGSSCHWELLE
16_km/h
GED_FL_ALS_DRL
nicht_aktiv
HEIMLEUCHTEN
wert_03
TAGFAHRLICHT_ECE
nicht_aktiv
AC_AUTO
aktiv
AC_BASIC
nicht_aktiv
AC_POLUTION
aktiv
ALARM_INDICATION
aktiv
AUX_OFF_TIME
r50
AUXILIARY_LAMP_ENABLE
nicht_aktiv
BOOT_RELEASE_ENABLE
aktiv
CAT1
nicht_aktiv
CLUTCH_OFF
wert_01
CLUTCH_ON
wert_01
DAYLIGHT_RUN_POWER
wert_01
DEFAULT_EXT_AMBIENT_TEMP
nicht_aktiv
DIPPED_BEAM_NAS
nicht_aktiv
DISABLE_FRESH_PARK
nicht_aktiv
DISABLE_RECIRC_PARK
nicht_aktiv
DO_MISLOCK_ON_ALL_RF
nicht_aktiv
EEROM_STATUS
r50
ENTRIEGELN_B_MOTOR_STOP
aktiv
FOG_DISABLE_WITH_TRAILER
aktiv
FRONT_FOG_NAS
nicht_aktiv
HALTEN_FB_OEFFNEN_TASTE
komfort_oeffnung
HEADLAMP_LEVEL_POSITION1
wert_01
HEADLAMP_LEVEL_POSITION2
wert_01
HEADLAMP_LEVEL_POSITION3
wert_01
HFS
nicht_aktiv
HFS_HIGH_TEMP_TIME
wert_01
HFS_LOW_TEMP_TIME
wert_01
HFS_OFF_TIME
r50
HR_HIGH_BAT_THRESHOLD
wert_01
HRW_HIGH_TEMP_TIME
wert_01
HRW_LOW_BAT_THRESHOLD
wert_01
HRW_LOW_TEMP_TIME
wert_01
HRW_OFF_TIME
r50
INDICATE_DURING_HAZARD
aktiv
KEY_DISARM
aktiv
KEYINTERLOCK_AUTO
manual
KEYINTERLOCK_ENABLE
nicht_aktiv
KOMFORTOEFFNUNG_SCHLOSS
aktiv
LAMP_WITH_AUX_OFF
aktiv
LAMP_WITH_AUX_SIDE
nicht_aktiv
LAZY_LOCK_WITH_KEY
aktiv
LIGHTS_ON_WITH_WIPERS
aktiv
LOCK_DIRECT_SUPERLOCK
aktiv
LOCK_DOUBLE_SUPERLOCK
nicht_aktiv
MAN_WISCHEN_IM_WASCHPROG
aktiv
MANUFACTURING_MODE
nicht_aktiv
MAX_ALARM_EVENTS
r50
MAX_ON_LEVEL
r50
NO_MAP_WITH_PERM_OFF
nicht_aktiv
NO_SOFT_ON_OFF
nicht_aktiv
NORMAL_MODE
aktiv
PARKING_LIGHTS
aktiv
POWER_WASH_MIN_OFF_TIME
r50
POWER_WASH_OFF_TIME
wert_01
POWER_WASH_ON_TIME
wert_02
RAMP_DOWN_INCREMENT
r50
RAMP_UP_INCREMENT
r50
REAR_WIPER_CONTINUOUS
nicht_aktiv
REF_POINT_STEPPER_MOTORS
r50
REMOTE_CONTROL
aktiv
REMOTE_DIRECT_SUPERLOCK
aktiv
REMOTE_DOUBLE_SUPERLOCK
aktiv
REMOTE_LAZY_LOCK
aktiv
SEL_ZV_SENDER
nicht_aktiv
SENSOR_REGEN
nicht_aktiv
SENSOR_SETTLE_TIME
r50
THRESHOLD_STEPPER_MOTOR
r50
TRANSIT_MODE
nicht_aktiv
TRIGGER_DURATION
r50
ULTRASONIC_WINDOW_OPEN
aktiv
VERRIEGELN_MIT_MOTOR_AN
nicht_aktiv
WIN_PINCH_ENABLE_DRIVER
aktiv
WINDOW_AUTO_UP_DRIVER
aktiv
WINDOW_AUTO_UP_PASS
aktiv
WINDOW_INCH_AUTO
nicht_aktiv
WINDOW_PINCH_ENABLE_PASS
aktiv
WINDOW_SHORT_DRIVER
aktiv
WINDOW_SHORT_PASS
aktiv
WINDOW_SHORT_RAISE_DELAY
r50
WINDOW_SUNROOF
nicht_aktiv
WIPER_BOOT_INHIBIT
aktiv
WIPER_CAM_DELAY
wert_01
WIPER_NO_PROG_REAR_WASH
aktiv
WIPER_PROGRAM_WASH_OPTION
option_2
WIPER_REAR_CAM_DELAY
wert_01
WIPER_WASHER_START_TIME
wert_01
WISCHER_GESCHW_ABHAENGIG
aktiv
FRONT_FOG_ENABLE
aktiv
HEADLAMP_LEVEL_TYPE
automatic
INERTIA_SW_FITTED
nicht_aktiv
MISLOCK_BEEP_ENABLE
nicht_aktiv
REAR_FOG_ENABLE
aktiv
DWA
nicht_aktiv
aktiv
ZV_SELEKTIV
nicht_aktiv
STANDRUECKSCHALTUNG
aktiv
16_km/h
GED_FL_ALS_DRL
nicht_aktiv
HEIMLEUCHTEN
wert_03
TAGFAHRLICHT_ECE
nicht_aktiv
AC_AUTO
aktiv
AC_BASIC
nicht_aktiv
AC_POLUTION
aktiv
ALARM_INDICATION
aktiv
AUX_OFF_TIME
r50
nicht_aktiv
BOOT_RELEASE_ENABLE
aktiv
CAT1
nicht_aktiv
CLUTCH_OFF
wert_01
CLUTCH_ON
wert_01
DAYLIGHT_RUN_POWER
wert_01
nicht_aktiv
DIPPED_BEAM_NAS
nicht_aktiv
DISABLE_FRESH_PARK
nicht_aktiv
DISABLE_RECIRC_PARK
nicht_aktiv
nicht_aktiv
EEROM_STATUS
r50
aktiv
aktiv
FRONT_FOG_NAS
nicht_aktiv
komfort_oeffnung
wert_01
wert_01
wert_01
HFS
nicht_aktiv
HFS_HIGH_TEMP_TIME
wert_01
HFS_LOW_TEMP_TIME
wert_01
HFS_OFF_TIME
r50
wert_01
HRW_HIGH_TEMP_TIME
wert_01
wert_01
HRW_LOW_TEMP_TIME
wert_01
HRW_OFF_TIME
r50
aktiv
KEY_DISARM
aktiv
KEYINTERLOCK_AUTO
manual
KEYINTERLOCK_ENABLE
nicht_aktiv
aktiv
LAMP_WITH_AUX_OFF
aktiv
LAMP_WITH_AUX_SIDE
nicht_aktiv
LAZY_LOCK_WITH_KEY
aktiv
aktiv
aktiv
nicht_aktiv
aktiv
MANUFACTURING_MODE
nicht_aktiv
MAX_ALARM_EVENTS
r50
MAX_ON_LEVEL
r50
nicht_aktiv
NO_SOFT_ON_OFF
nicht_aktiv
NORMAL_MODE
aktiv
PARKING_LIGHTS
aktiv
r50
POWER_WASH_OFF_TIME
wert_01
POWER_WASH_ON_TIME
wert_02
RAMP_DOWN_INCREMENT
r50
RAMP_UP_INCREMENT
r50
nicht_aktiv
r50
REMOTE_CONTROL
aktiv
aktiv
aktiv
REMOTE_LAZY_LOCK
aktiv
SEL_ZV_SENDER
nicht_aktiv
SENSOR_REGEN
nicht_aktiv
SENSOR_SETTLE_TIME
r50
r50
TRANSIT_MODE
nicht_aktiv
TRIGGER_DURATION
r50
aktiv
nicht_aktiv
aktiv
aktiv
WINDOW_AUTO_UP_PASS
aktiv
WINDOW_INCH_AUTO
nicht_aktiv
aktiv
WINDOW_SHORT_DRIVER
aktiv
WINDOW_SHORT_PASS
aktiv
r50
WINDOW_SUNROOF
nicht_aktiv
WIPER_BOOT_INHIBIT
aktiv
WIPER_CAM_DELAY
wert_01
aktiv
option_2
wert_01
wert_01
aktiv
FRONT_FOG_ENABLE
aktiv
HEADLAMP_LEVEL_TYPE
automatic
INERTIA_SW_FITTED
nicht_aktiv
MISLOCK_BEEP_ENABLE
nicht_aktiv
REAR_FOG_ENABLE
aktiv
And here's my KMB_R50.C05
CODIERUNG_ERFOLGT
codiert
K_ZAHL_TACHO
46463_imp/km
K_ZAHL_TACHO_KOMPL
46463_imp/km
TANK_SICHERHEITSFAKTOR
wert_01
TANK_SCHWELLE_RESERVE
8_l
TANK_MITTLUNGSZEIT
wert_01
TANK_BERUHIGUNGSZEIT
wert_01
K_ZAHL_WEG
46463_imp/km
K_ZAHL_WEG_KOMPL
46463_imp/km
MOTOR_ART
benziner
SPRACHE
englisch
TEMPERATUR_EINHEIT
grad_c
WEGSTRECKE_EINHEIT
km
WEG_DURCHSCHNITT
km/h
VERBRAUCH_D1
km/l
BC
aktiv
ASC
aktiv
LL/RL
linkslinker
GURTWARNUNG
ohne_gurtschlosskontakt
TANK_SCHWELLE_AUF/AB
wert_01
SIA_GRENZE_INSPEKTION
25.000_km
SIA_GRENZE_ZEIT
716_tage
SIA_LITER_GRENZE
1.6_cooper_s
AUSSENTEMP_DELTA_K1
wert_01
AUSSENTEMP_ZEITKONST_Z1
wert_01
AUSSENTEMP_ZEITKONST_Z2
wert_01
LICHTWARNUNG
aktiv
GETRIEBE_ART
handschalter
TANK_VORHALT_REICHW
wert_01
WEG_EINHEIT
km
LETZTER_SERVICE
grundcode_var
AKUSTIK_DWS
aktiv
DWS
aktiv
ZUENDSCHLUESSEL_WARNUNG
aktiv
AUSSENTEMP_WARN_AKUSTIK
aktiv
LIMIT
nicht_aktiv
GONG_1
wert_01
ANZEIGE_FUEHRENDER_NULLEN
aktiv
KALIBRIERUNG_TACHO
wert_01
LCD_DIMMUNG_MAX
wert_01
LCD_DIMMUNG_MIN_NACHT
wert_01
LCD_DIMMUNG_MIN_TAG
wert_01
REMOTE_KOMBI
dzm
AUSSENTEMP_SENSOR
aktiv
A_TEMP_DELTA_OFFSET
wert_01
A_TEMP_OFFSET_SCHWELLE
wert_01
AKUSTIK_TANK_RESERVE
aktiv
AKUSTIK_WARN_UEB_LEITUNG
nicht_aktiv
AKUSTIK_WARN_UEBER_BUS
aktiv
AUSSENTEMP_DELTA_K2
wert_01
AUSSENTEMP_SPERRZEIT_2
wert_01
AUSSENTEMP_SPERRZEIT_3
wert_01
AUSSENTEMP_ZEITKONST_Z3
wert_01
AUSSENTEMP_ZEITKONST_Z4
wert_01
BC_ANGEZEIGTE_GESCHW
wie_tacho
BC_GESCHW_ANZEIGE_DIGITAL
aktiv
BC_TWSZ_2
nicht_aktiv
BREMSFLUESS_FILTER_ZEIT
25_sec
BREMSFLUESSIGKEIT_UEBER
can_bus
GONG_FREQ2
wert_01
KALIBRIERUNG_WEGSTRECKE
wert_01
KOMBI_TYP
ece
MOTORHAUBE_OFFEN_WARNUNG
aktiv
ODOMETER_OFFSET
wert_01
PREDRIVE_CHECK
aktiv
RUECKWAERTSGANG_WARNUNG
nicht_aktiv
SCHWELLE_DZM_WARNFELD_1
nicht_aktiv
SCHWELLE_DZM_WARNFELD_2
nicht_aktiv
SCHWELLE_DZM_WARNFELD_3
nicht_aktiv
SCHWELLE_DZM_WARNFELD_4
aktiv
SIA_LITER_ZAEHLER
SIA_TAG_ZAEHLER
STOPPUHR_0_AUF_100
nicht_aktiv
STOPPUHR_1/4_MEILE
nicht_aktiv
TANK_1_ADC_FEHLER_OG
wert_01
TANK_1_ADC_FEHLER_UG
wert_01
TANK_2_ADC_FEHLER_OG
wert_01
TANK_2_ADC_FEHLER_UG
wert_01
TANK_FEHLER_SCHWELLE
wert_01
TANK_SCHW_RES_HYSTERESE
wert_02
TANKDAEMPFUNG_FAHRT_AB
wert_02
TANKDAEMPFUNG_FAHRT_AUF
wert_02
TANKDAEMPFUNG_NORMAL_AB
wert_01
TANKDAEMPFUNG_NORMAL_AUF
wert_01
TANKGEBER_1_LITER
kennlinie_02
TANKGEBER_1_WIDERSTAND
TANKGEBER_2_LITER
kennlinie_02
TANKGEBER_2_WIDERSTAND
TLETZ
wert_01
UEBERTEMP_WARNUNG
nicht_aktiv
VERBRAUCH_2
aktiv
VES_INFO
r50
WARN_GESCHW_LIMIT
nicht_aktiv
ZEITINSP_DISPLAY_FLAG
icon_wird_nicht_angezeigt
ZEITINSPEKTION
aktiv
ZEITINSPEKTION_VORGEZOGEN
aktiv
ANZEIGE_CFC
nicht_aktiv
AUSGABE_FEHLERSPEICHER
aktiv
BC_ANZ_NACH_ATEMP_WARN
aktiv
BC_QUITT_ATEMP_WARN_LSS
aktiv
CC_AUSSENTEMPERATUR
aktiv
DWS_UEBER
can_bus
TANK_NICHT_MESSBAR_OBEN
wert_02
CODIERUNG_ERFOLGT
codiert
K_ZAHL_TACHO
46463_imp/km
K_ZAHL_TACHO_KOMPL
46463_imp/km
wert_01
8_l
TANK_MITTLUNGSZEIT
wert_01
wert_01
K_ZAHL_WEG
46463_imp/km
K_ZAHL_WEG_KOMPL
46463_imp/km
MOTOR_ART
benziner
SPRACHE
englisch
TEMPERATUR_EINHEIT
grad_c
WEGSTRECKE_EINHEIT
km
WEG_DURCHSCHNITT
km/h
VERBRAUCH_D1
km/l
BC
aktiv
ASC
aktiv
LL/RL
linkslinker
GURTWARNUNG
wert_01
25.000_km
SIA_GRENZE_ZEIT
716_tage
SIA_LITER_GRENZE
1.6_cooper_s
AUSSENTEMP_DELTA_K1
wert_01
wert_01
wert_01
LICHTWARNUNG
aktiv
GETRIEBE_ART
handschalter
TANK_VORHALT_REICHW
wert_01
WEG_EINHEIT
km
LETZTER_SERVICE
grundcode_var
AKUSTIK_DWS
aktiv
DWS
aktiv
aktiv
aktiv
LIMIT
nicht_aktiv
GONG_1
wert_01
aktiv
KALIBRIERUNG_TACHO
wert_01
LCD_DIMMUNG_MAX
wert_01
wert_01
LCD_DIMMUNG_MIN_TAG
wert_01
REMOTE_KOMBI
dzm
AUSSENTEMP_SENSOR
aktiv
A_TEMP_DELTA_OFFSET
wert_01
wert_01
aktiv
nicht_aktiv
aktiv
AUSSENTEMP_DELTA_K2
wert_01
wert_01
wert_01
wert_01
wert_01
wie_tacho
aktiv
BC_TWSZ_2
nicht_aktiv
25_sec
can_bus
GONG_FREQ2
wert_01
wert_01
KOMBI_TYP
ece
aktiv
ODOMETER_OFFSET
wert_01
PREDRIVE_CHECK
aktiv
nicht_aktiv
nicht_aktiv
nicht_aktiv
nicht_aktiv
aktiv
SIA_LITER_ZAEHLER
SIA_TAG_ZAEHLER
STOPPUHR_0_AUF_100
nicht_aktiv
STOPPUHR_1/4_MEILE
nicht_aktiv
wert_01
wert_01
wert_01
wert_01
wert_01
wert_02
wert_02
wert_02
wert_01
wert_01
TANKGEBER_1_LITER
kennlinie_02
TANKGEBER_2_LITER
kennlinie_02
TLETZ
wert_01
UEBERTEMP_WARNUNG
nicht_aktiv
VERBRAUCH_2
aktiv
VES_INFO
r50
WARN_GESCHW_LIMIT
nicht_aktiv
ZEITINSPEKTION
aktiv
aktiv
ANZEIGE_CFC
nicht_aktiv
aktiv
aktiv
aktiv
CC_AUSSENTEMPERATUR
aktiv
DWS_UEBER
can_bus
wert_02
WINDOW_INCH_AUTO
and
MISLOCK_BEEP_ENABLE
can do for me?
WINDOW_INCH_AUTO
and
MISLOCK_BEEP_ENABLE
can do for me?
I've got this cable. http://www.ebay.nl/itm/181315330804?...84.m1439.l2649
I've installed Win XP SP2 in a VM and am using the drivers wicht came with the cable. then i've downloaded the bmw-suite and updated everything and then installed NCS Expert. last;y, i've downloaded NCS Expert (for) Dummies. this combination works flawless!
Awesome! and btw you have already delved further into this then I have. I bought my cable and software from ebay and the support is on its own private website for buyers. The software was 100% auto install and I didn't have to do much other then click a few icons and the software did it for me.
Finally I find the thread and a answer that suits me! I want to program a few things in my R53, but I'm not so skilful to deep programming the options. Can you please tell me what cable and program did you bought on EBay? I'll buy it right away! Thanks in advance, cheers from Chile
The person I bought my things from is on "US.ebay" and goes under the name bmwfanatiq. I am sure he is on other ebay servers under the same name. His website is http://bmwmotion.com . I think you need to have already purchased his items before you are able to access the site but there it is just incase.
