Electrical NCSExpert DIY(do it yourself)
#53
#54
spreadsheet access
Thanks to jbourne , I have allocated on a spreadsheet the mods that I have tried and know they work - ppl who have tried other new mods are adding them on the sheet.
Here is the spreadsheet , you need to request to view it (please do not edit randomly afterwards) and I will allow you view/edit it.
FIY,be sure to know what you are doing,if you are not sure, click back here, check the step, you can really mess up your car if you code over the wrong modules.
#55
#57
#58
Requested.
#61
#62
#65
Definitely
Iam usually pretty quick in giving the access, like I said, the longest someone had to wait was probably when I was sleeping
anyone who waited more than 5hrs(yes sometimes iam away from my computer) please send me a private message with the email adress you want to request from.
thanks all !!
PS: SO I WAS CHECKING THE SPREADSHEET REVISIONS AND I SEE SOME PPL ERASING DESCRIPTIONS AND FORMULA STRINGS -I HAVE ASKED BEFORE NOT TO EDIT RANDOMLY THE SPREADSHEET ESPECIALLY IF IT IS NOT TO EDIT SOMETHING USEFUL
LATEST PERSON IS SMARCO111, I DONT KNOW IF YOU DID IT ON PURPOSE BUT YOU ERASED STUFF ON THE SPREADSHEET AND LEFT IT BLANK.
IT IS NOT COOL TO SEE STUFF GOING MISSING FOR NO REASON, I WILL KEEP ON EYE ON THIS MORE CLOSELY NOW.
I REALLY DONT WANT TO LOCK THE SPREADSHEET FROM EDITING AS I WANT PPL TO BE ABLE TO ADD THEIR DISCOVERIES.
PLEASE BE CAREFUL ...
thanks all !!
#67
DogfaceSGM (02-13-2022)
#68
2MULF - Bluetooth/USB module
2RAD - Radio Module
4BMOT - Digital Motor Electronics (DME)
ABG - Airbag Module
AHM - Trailer Module
AMPH - Hi-Fi Amplifier
CAPPL - Navigation Module
CAS - Car Access System
CCC - Car Communication Computer
CID - Central Information Display
DDE - Digital Diesel Electronics
DSC - Dynamic Stability Control
EGS - Electronic Transmission Control
EPS - Electromechanical Power Steering
FRM - Footwell Module (lighting / window controls)
IHKA - Integrated Automatic Heating/Cooling System
IHKS - Integrated Heating/Cooling System
IHS - Integrated Heater Control
KOMBI - Instrument Cluster
MJOY - MINI joystick
PDC - Park Distance Control
PGS - Passive Go System
RLS - Rain-Light Sensor
SHD - Sunroof Module
SPEG - System Power Electronics Gateway (fuse box "brains")
SZL - Steering Column Switch Cluster
#69
#70
All you should have to do is add option $550 (ON-BOARD COMPUTER) to your vehicle order string (in the CAS and FRM modules) and then "Process Car" in NCS Expert. It should default all the modules and activate the function.
Give it a shot and let us know!
#75
on
https://www.northamericanmotoring.co...071-post3.html
This post will help you out!
What I recommend is experiement with the trace files, then when you know it works fine, then modify the VO. If you don't modify the VO before your car gets connected to ISTA/P at the dealer, the car will give errors on their system since it will find the sat tuner without it being in the VO.
