Drivetrain Aquamist HFS Methanol Injection Systems
Old 04-26-2014, 02:10 PM
wzabrouski's Avatar
wzabrouski
wzabrouski is offline
Who is using a restrictor? Read on another mini forum it was suggested to not use one.
  #52
Old 04-26-2014, 02:15 PM
Systemlord's Avatar
Systemlord
Systemlord is offline
Question, how do you tune for meth? Would you just go for a Batte tune stage 2 and simply mention you're running meth?
  #53
Old 04-26-2014, 02:34 PM
cerenkov's Avatar
cerenkov
cerenkov is offline
I am, 0.7 mm coupled with a 0.6 mm jet. Restrictors are useful to dial in the desired flow rate, I don't think they are good or bad.
I believe a good starting point for flow rate is 20% of total injector flow. So if stock injectors are 400cc (I couldn't find a good number for this), multiply by 4 to get 1600. 20% of 1600 is 320cc. I measured 275cc, so I'm a little low but I'm fine with that for now.
I think it's best to start out low and work up.
  #54
Old 04-26-2014, 10:16 PM
wzabrouski's Avatar
wzabrouski
Today I got all the wires to the ECU ( did not make any connections yet) all the wires into the cabin, installed the FAV, installed the jet adapter and installed the gauge. All I have left is to make the connections at the ECU and make the positive battery connection.
Attached Thumbnails Aquamist HFS Methanol Injection Systems-image-2003092041.jpg
  #55
Old 04-26-2014, 11:23 PM
Agbullet25's Avatar
Agbullet25
Agbullet25 is offline
That's where I was thinking to install the gauge if I got this system. Just out of curiosity and because it's late and I'm being lazy, is there a MINI-specific install guide for the system?
  #56
Old 04-27-2014, 05:32 AM
wzabrouski's Avatar
wzabrouski
There is. It comes with the kit. It is for the R56 so my install was slightly different since I have a Countryman. Overall 95% accurate. Only difference was the tank.
  #57
Old 04-27-2014, 01:22 PM
miniforozzie's Avatar
miniforozzie
miniforozzie is offline
let's post some pics of how our controllers are mounted. I'm curious to see how other people mounted their controller.
here's mine:
  #58
Old 04-27-2014, 01:28 PM
wzabrouski's Avatar
wzabrouski
Originally Posted by miniforozzie
let's post some pics of how our controllers are mounted. I'm curious to see how other people mounted their controller. here's mine:
Controller or gauge?
  #59
Old 04-27-2014, 02:01 PM
cerenkov's Avatar
cerenkov
cerenkov is offline
Does the vent pod swivel or is it fixed?
  #60
Old 04-27-2014, 02:02 PM
miniforozzie
The controller mainly but I'd like to see some gauges too.
  #61
Old 04-27-2014, 02:47 PM
c0op3r's Avatar
c0op3r
c0op3r is offline
Controller mounted under the dash:
Gauge:
  #62
Old 04-27-2014, 03:37 PM
wzabrouski's Avatar
wzabrouski
Up and down.
  #63
Old 04-28-2014, 01:02 PM
wzabrouski's Avatar
wzabrouski
Almost done
Attached Thumbnails Aquamist HFS Methanol Injection Systems-image-2978891633.jpg   Aquamist HFS Methanol Injection Systems-image-1666573884.jpg
  #64
Old 04-28-2014, 01:38 PM
cerenkov's Avatar
cerenkov
cerenkov is offline
Looks good. How big is the tank?
I ended up Velcro'ing the controller box to the ceiling of the glove box. Can't even see it when you open the glove box.
  #65
Old 04-28-2014, 01:58 PM
wzabrouski's Avatar
wzabrouski
2 gallons. I velcro'd the controller to the door of the in cabin filter door underneath the dash.
  #66
Old 05-02-2014, 08:17 AM
cerenkov's Avatar
cerenkov
cerenkov is offline
Recent logging shows that the intake cooling effects are drastically reduced when the humidity is high. The other morning it was misty with a relative humidity around +95% and the IAT was only about 5 F degrees below ambient. Where normally it would be closer to 20 F degrees below ambient.
I had never really thought about it before but it does make sense. Maybe I'm just stating the obvious.
Currently I'm using 100% methanol and I'm waiting for a 80 F, low humidity day to log a run to compare to my 80% and 95% methanol runs. Then I get data for 50/50 mix.
  #67
Old 05-11-2014, 03:48 AM
johntotah94's Avatar
johntotah94
johntotah94 is offline
What tools were required for installation? Will be ordering soon.
Also being over $1,000, it doesn't come with a gauge pod?
  #68
Old 05-11-2014, 04:54 AM
cerenkov's Avatar
cerenkov
cerenkov is offline
For tools you will need a drill, drill bit and tap. Howerton sell the tap and drill bit, buy it from him. A basic drill bit set would be nice. This is to install the jet in the charge pipe.
A standard set of metric wrenches and screw drivers. Nothing special required.
Gauge pod is not included.
  #69
Old 05-11-2014, 09:20 AM
johntotah94
For tools you will need a drill, drill bit and tap. Howerton sell the tap and drill bit, buy it from him. A basic drill bit set would be nice. This is to install the jet in the charge pipe. A standard set of metric wrenches and screw drivers. Nothing special required. Gauge pod is not included.
Cool. Do you know which sizes of the drill bit and tap that I need? Thanks again.
  #70
Old 05-11-2014, 09:48 AM
c0op3r's Avatar
c0op3r
c0op3r is offline
1/8"-27 NPT Tap
11/32" Drill Bit
7/8" Drill Bit
I got my parts from Amazon as I am a Prime Member and get free shipping, I did not need the 7/8" Bit.
If you are going to Drill and Tap in place, I would also get some heavy grease. You will fill the Drill Bit and the Tap with grease to catch the metal shavings.
Document from Howerton Eng - Installation DOC for MINI Cooper
  #71
Old 05-11-2014, 09:51 AM
cerenkov's Avatar
cerenkov
cerenkov is offline
Actually, when you order the kit, I'll be happy to mail the tap and bit (used only once) to you free of charge, I have no further need of them.
  #72
Old 05-11-2014, 01:28 PM
johntotah94
That would be great! I just bought a kit.
  #73
Old 05-11-2014, 02:32 PM
wzabrouski's Avatar
wzabrouski
Craven speed vent gauge works well.
  #74
Old 05-18-2014, 06:24 AM
wzabrouski's Avatar
wzabrouski
Has anyone done the install on an R60/Countryman? Finally got around to the final step of making the ECU connections and the instructions from the R56 seemed different.
Step 3 is the MAP sensor. On the top connector, the instructions on page 23 stated the middle connector? But the diagram shows the connection on the X60232 connector. Also, why does it look like pin 31 has a plug/blank in it and not a wire?
Any help would be appreciated. I stopped once I saw this to make sure I was making the correct connections.
Attached Thumbnails Aquamist HFS Methanol Injection Systems-image-735952074.jpg   Aquamist HFS Methanol Injection Systems-image-2065752892.jpg
  #75
Old 05-18-2014, 08:53 AM
cerenkov's Avatar
cerenkov
cerenkov is offline
My install was on a R56 but I think they are the same connectors as the R60. I followed the diagram in the back of the manual exactly and only used the photos as "guidance". There are no connections to be made in the middle connector. Only the first and third connectors.
Here's a photo of my connector:
Note that the connector has more rows on it then shown in the diagram. I just counted from the end where #1 starts and all the colors matched up perfectly with what is shown in the diagram. Make sure that you are counting and identifying #31 correctly (use the colors as reference - they should match up exactly as shown in the diagram).
Triple check everything.
Quick Reply: Drivetrain Aquamist HFS Methanol Injection Systems
