Drivetrain Any opinions on the Single Mass valeo clutch kit?
Old 10-21-2011, 08:15 PM
Professor's Avatar
Professor
Professor is offline
the quality is awesome. I love it over the old dual mass. I have installed a couple of these for other locals with no issues.
Pedal feel is great, not to hard and not to soft. Engagement is very smooth and quiet.
And the surface area is the same as the oem one.
  #27
Old 10-21-2011, 10:07 PM
mininuke's Avatar
mininuke
mininuke is offline
It looks like the Valeo is going to be my choice. Thanks for the info.
  #28
Old 10-25-2011, 06:06 PM
WayMotorWorks's Avatar
WayMotorWorks
WayMotorWorks is offline
Vendor
We've sold several of the Valeo kits and not had any problems. And the price really makes them attractive.
HOTCHKIS | DDM | CRAVEN | AKRAPOVIC | NM ENGINEERING | MEGAN | FORGE | IE | OS GIKEN | POWERFLEX and more
  #29
Old 11-29-2011, 06:15 AM
DJDUPONT's Avatar
DJDUPONT
DJDUPONT is offline
Had my Valeo installed over the holiday week, since i was out of town! Got it back last night and so far im loving it! Feels great, grabs really good! To me the pedal feels a little to lite, but my OEM clutch was so hurt up that i had to take my foot of the floor just to push it down. I guess i just need to get used to it. But in all so far so good I will follow up in a few months.
  #30
Old 11-29-2011, 06:27 AM
PoonRacing's Avatar
PoonRacing
PoonRacing is offline
6,000+ miles on my
  #31
Old 11-29-2011, 08:56 AM
mininuke's Avatar
mininuke
mininuke is offline
Nice to hear good things about the Valeo kit. I have mine still in the box waiting to be installed. Can't wait.
  #32
Old 11-29-2011, 03:39 PM
SimTechDJ's Avatar
SimTechDJ
SimTechDJ is offline
I bought my car used earlier this month... already has the Valeo kit in it.
I like it!
I have driven a few minis now and while i would like a more track oriented clutch, this one is very smooth, predictable and holds well. Great price too if i need to replace it!
  #33
Old 11-29-2011, 05:58 PM
Thomas1's Avatar
Thomas1
Thomas1 is offline
Ordered mine 2 days ago from Way Motor Works. He walked me through all the available options as far as clutches and we decided on the valeo single mass kit! cant wait to get it installed later this week. I'll post a review of it if anyone is interested.
  #34
Old 11-30-2011, 02:13 AM
Gamm's Avatar
Gamm
Gamm is offline
It sometimes is a bit tough to get into first gear but overall a good value for its price.
I've had it installed for a couple of months now.
  #35
Old 11-30-2011, 08:48 AM
DJDUPONT's Avatar
DJDUPONT
DJDUPONT is offline
Do any of yours make noise? When i let mine out it it clicks a little bit right as it engages? I'm a little worried about it but, everything seems fine, shifts nice and grabs good.
  #36
Old 12-02-2011, 03:53 PM
Thomas1's Avatar
Thomas1
Thomas1 is offline
Just dropped mini off at the local transmission shop, is there a reccomended method for this clutch break in? I assume its just driving it very conservatively for 4 to 500 miles.
  #37
Old 12-15-2011, 05:45 PM
mininuke's Avatar
mininuke
mininuke is offline
I just picked up my car from the shop where I had the Valeo kit installed. Initial impressions are not stellar. First, the clutch pedal effort is to light, second, it is slipping!!!! Not even stepping on it. When I engaged the clutch at a traffic light which is going up on an incline the clutch made a shuddering sound just like the previous clutch. WTF?
It is 42 degrees outside and wet. I am sure that the clutch slipped but at another time it felt as if the tire were spinning while underway in the rain at less than 1/3 throttle.
I am very concerned that the mechanic maybe forgot to prep the flywheel before installation.
Could this be normal on a brand new clutch/flywheel/release bearing/slave cylinder installation? Has anyone experienced anything like this? Is there any type of adjustment to be made to something that may be preventing the clutch to fully engage?
Let's suppose that the flywheel was not prepped, will it eventually break-in? Maybe I am worrying too much. I should just break it in for about 500 miles of stop and go traffic and let the clutch seat properly.
Thank you for your responses.
  #38
Old 12-15-2011, 07:24 PM
DJDUPONT's Avatar
DJDUPONT
DJDUPONT is offline
Just calm down! Its going to be OK! First off my clutch def did not slip but i also didnt rev the car past 4k in any gear for the first 1000 miles. You said its raining im sure it was your tires slipping! Break it and dont really get on it untill you have at least 1k on it.
I was freaking out to cause of an engament noise ended up just being my pedal.
"The clutch pedal effort is to light" dont worry i was like WTF!!! too, you will get used to it.
  #39
Old 12-15-2011, 07:46 PM
mininuke's Avatar
mininuke
mininuke is offline
Thanks for the reassurance. I am shifting early and frequently. Not even past 3k. Will it be normal to for the clutch to shudder during take off on a slight incline?
  #40
Old 12-15-2011, 08:20 PM
WayMotorWorks
Vendor
From what your saying it sounds like it's possible that they didn't bleed your clutch right, or you have a faulty slave cylinder. I've replace 100 slave cylinders so it wouldn't surprise me. But if the shop that did it disconnected the clutch line and didn't have the tool to bleed the clutch then there is prob air in the system still, and yes that will destroy your clutch as it won't fully release when you press on it. I never advise opening up the clutch line unless its absolutely necessary. You can do a clutch without disconnecting it, that's how we do it.
There is no prepping the flywheel, just make sure it's clean.
  #41
Old 12-15-2011, 08:29 PM
mininuke's Avatar
mininuke
mininuke is offline
I think the system needs to be bled. The slave was replaced and they told me they had problems bleeding the clutch. I suspect that it wasn't done properly. I can actually press the pedal all the way with my hand with little effort. I hope it's not too late. I drove it for about 5 miles.
  #42
Old 12-15-2011, 10:57 PM
Gamm's Avatar
Gamm
Gamm is offline
+1
As for the light clutch pedal, as mentioned before, I think it's quite normal for this kit as I am experiencing it aswell. Totally different compared to the original, which makes you worry a bit initially, but I've had it for a few k miles now and no issues whatsoever.
  #43
Old 12-16-2011, 08:15 AM
mininuke's Avatar
mininuke
mininuke is offline
I am going to attempt to bleed it myself if I am able to fashion a bleed tool in order to compress the slave cylinder. I wonder if it is possible to do a one man clutch bleed?
  #44
Old 12-16-2011, 02:43 PM
mininuke's Avatar
mininuke
mininuke is offline
I was able to bleed the clutch backwards from the slave up. I connected the tubing to the slave cylinder release valve and used a pressure oil can. I pumped until I didn't see any bubbles coming out in the fluid reservoir. The pedal feels better but the clutch still slips on inclines. Will this go away as the clutch breaks in?
  #45
Old 12-16-2011, 05:33 PM
CrazyIvan's Avatar
CrazyIvan
CrazyIvan is offline
Not likely. Better take it back and have them inspect it. I hope you called them as soon as you left the shop and told them it was slipping.
  #46
Old 12-16-2011, 05:37 PM
mininuke's Avatar
mininuke
mininuke is offline
I did, but will have to wait until Monday. I drove it for about 25 miles stop and go traffic with a lot frequent shifting even though I didn't need to shift. It only made a slight shudder once. At one instance I had to accelerate a little hard in order to merge into traffic and it held well. I wonder if I shouldn't drive the car until the shop looks at it.
  #47
Old 12-16-2011, 05:41 PM
CrazyIvan's Avatar
CrazyIvan
the less miles the better till they look at it. If it has a lot they will try and say you were racing, burn out, etc don't give them any thing to use as an excuse to get out of it.
  #48
Old 12-16-2011, 06:11 PM
mininuke's Avatar
mininuke
mininuke is offline
Makes sense.
  #49
Old 12-20-2011, 06:55 AM
EmaciatedCow's Avatar
EmaciatedCow
EmaciatedCow is offline
any update on your car?
  #50
Old 12-20-2011, 10:11 AM
mininuke's Avatar
mininuke
mininuke is offline
I'm pretty bummed, I haven't had the chance to take it to the shop. The clutch engagement is smooth and shifting is crisp. The problem that I have is a shudder when I take off on first gear. It doesn't happen all the time but it is worrisome. The other problem is occasional slipping on high gears. I had to step on it because of a semi-truck coming fast at me. The clutch slipped for a few seconds. I hope as it breaks in the conditions mentioned will eventually go away.
Any ideas?
Quick Reply: Drivetrain Any opinions on the Single Mass valeo clutch kit?
