16" Winter Steelies
16" Winter Steelies
Living in Colorado, and our Mini being delivered with summer tires last month, I decided to order up some winter wheels and tires.
Found on Ebay some 16" x 6.5" Black Steelies with 5 x 112 bolt pattern, +50 offset and 66.6 center hub. My question is, the center hole for a center cap is 2.5" which is bigger than the stock Mini caps. Any recommendations on what to put there? Or just run naked
I put some Conti Winter Viking Contact 7s on there in 195/55-16 size.
the center hub hole on the wheel is 66.6mm I forgot that the holes in the steelies are made to accommodate the actual axle hubs to fit through the wheel. And there would be no room for the standard mini Center cap for aluminum wheels. Needs more of a hub cab center cap, like VWs use.
TheAmericanJob
Tires, Wheels, & Brakes
Jan 10, 2017 09:12 AM
jmsamr
Oct 3, 2012 02:15 PM
R50/53 Winter tires/wheels for MCS
UUNetBill
Aug 8, 2005 08:19 PM
