New N14 & N18 Engine Heat Shields/Covers
Old Nov 14, 2025 | 01:39 PM
ECS Tuning
Crafted from 18-gauge 304 stainless steel, this heat shield delivers superior thermal protection thanks to 304SS’s low thermal conductivity and excellent heat resistance. It effectively deflects and dissipates radiant heat away from your ignition coils and wiring, helping to extend component life and maintain reliable performance.
This also acts a design cover which completes the look of the factory valve cover that seems to be out of place!
Works with aftermarket and OEM factory main valve cover that is plastic or upgraded metal! Like Bremmen Parts!
The shield offers maximum coverage and works seamlessly with both plastic and metal valve covers, utilizing the factory valve cover mounting stud and OEM grommet for a secure, vibration-resistant fit. Its durable brushed finish complements your engine bay while standing up to the harshest heat cycles.
  • 18-gauge 304 Stainless Steel
  • Specifically designed for N14/N18 engines for maximum coverage and heat shielding
  • Works with both plastic and metal valve covers
  • Utilizes the factory mounting stud found on the valve cover and the factory grommet found on the factory engine cover
  • The factory valve cover does not have a front full plastic cover, just a little snap-in cover near the main harness in the front. This small plastic part stays in place when the metal is installed over it.
  • In order to change oil or add oil plate is simply removed with two round-head Allen screws at the bottom.
N14 Engine
N18 Engine
Fitment:
R55-R61 MINI Cooper S/JCW 2007-2016
N14 and N18 Turbo Engines only!
And Free shipping!
"Click HERE for the New ECS Heat Shield Kit
Sep 7, 2023 01:36 PM
Jun 6, 2023 01:52 PM
Nov 7, 2017 09:20 AM
May 19, 2017 01:28 PM
Oct 24, 2016 11:48 AM
