New F54 MINI Clubman ECS Coilovers!
Old Aug 27, 2025 | 01:01 PM
ECS Tuning
Our brand new F54 2016+ MINI Clubman Coilover line was designed with our daily drivers in mind! Our focus was to improve on the performance and look of the suspension, without forgoing any comfort. Like many of the top-tier coilovers, these coilovers feel as smooth and comfortable as a stock setup, while giving you an aggressive look and vastly improved handling, all at a fraction of the price!
Dial in your suspension with 32 way adjustable damping coilovers to improve the Performance, and Style of your MINI!
PERFORMANCE FEATURES
32 levels of rebound damping adjustment
Lowering Adjustment of: Stock to 3 1/4" Front drop and Stock to 1 5/8" Rear drop
Max lift: 1/4" over stock. This is not an Overland product, can also be used at stock height.
Adjustable damping, monotube shocks/struts paired with optimized progressive rate coil springs gives your vehicle road-sticking grip with reduced body roll for exceptional confidence in your vehicle's handling. With your vehicle's new, lower ride height the center of gravity is now moved lower, further improving handling performance
Adjustable front bodies allow you to set the ride height while maintaining correct spring pre-load
Adjustable front and rear bodies allow the shock to operate in the correct valving range, regardless of ride height
Spring Rates: Front is 6kg/mm, Rear is 6kg/mm
PRODUCT DESIGN
Strut and shock bodies finished with a durable gloss black powder coat for good looks and great longevity
Threaded portions are are clear zinc coated for optimum corrosion protection against rain and salt
Coil springs are powder-coated Reflex Silver Metallic finish for durability
Red anodized, billet aluminum lower spring seats with locking collars allow for quick, on the car, adjustability with the included spanner wrenches
Integrated bump stops
Fitment: Fits F54 MINI Cooper Clubman (2016 - 2024)
For vehicles without EDC/DDC
And Free shipping!
"Click HERE for the F54 MINI Clubman Coilovers
Old Sep 12, 2025 | 08:28 AM
Now these were tested on the F60 Countryman and Fit!!
https://www.ecstuning.com/b-ecs-part.../054788la01~a/
Mar 30, 2018 02:46 PM
Jul 26, 2017 08:04 AM
PelicanParts.com
Jul 29, 2015 09:25 AM
