MC40 JCW Sport Gauges - Carbon Fiber - ECS New!
ECS Tuning
Rare and no longer available from MINI is the factory (MC40) JCW Sport Gauges. 82940015951 OEM Part. This Gauge Holder is now back to life and in carbon fiber! Mounts in the center console of the original factory gauges pods that were a factory part on the special edition 2004 MINI Cooper S MC40.
This is just the panel to hold the VDO style OEM gauges.
Comes in carbon fiber with gloss coat.
Great for adding those factory style gauges such as Oil Pressure and Voltage.
Can hold two VDO style gauges.
For VDO Gauges Use : One of each Part number 310-106 and 332-103
Sensor 323-055 or oem 82940004581 and washer noted on part.
For replacement upgrade over the factory trim.
If installing without factory kit Aux installed, you will need to wire your own harness and plugs.
This can also be used as an upgrade for the stock black factory holder.
"Click HERE for the MINI Cooper ECS JCW Sport Aux Gauges "
"Click HERE for the Sensor 323-055"
"Click HERE for the VDO Oil Temp"
"Click HERE for the VDO Voltmeter"
Carbon fiber unit in stock! Can be used as an upgrade replacement for the stock unit if you have an MC40 or optioned.
