Mini R55 Side Splitters
Old Mar 22, 2017 | 07:36 AM
SneedSpeed's Avatar
SneedSpeed
Clean up the side profile of your MINI R55 Clubman with our black HD polyethylene side splitters. Easy to install and made of the same material that our, life time guaranteed, front splitters are made of, so you know they won't break or fade. Stock lift / jack blocks are retained, side splitters are installed to the MINI factory plastic side skirt with supplied hardware. Complete kit for 1 car and includes all mounting hardware.
Installation is very easy as the side splitters are pre drilled for mounting. Hold the side splitter up to the under side of the car's side skirt, mark holes to drill through factory side skirt, drill holes, install bolts through side splitter and skirt and tighten nuts on top side of skirt. You pull the skirt down under the car to get to the inside of it. Should take about than 1 hour to install.
Link: http://www.sneed4speed.com/r55-mini-...side-splitter/
Attached Thumbnails Mini R55 Side Splitters-splitter.jpg   Mini R55 Side Splitters-splitter2.jpg   Mini R55 Side Splitters-splitter3.jpg   Mini R55 Side Splitters-splitter1.jpg
