SneedSpeed Mini R53 and R56 Race Wing
Old Jan 25, 2017 | 07:41 AM
SneedSpeed's Avatar
SneedSpeed
Fully adjustable proprietary 3D designed carbon fiber rear wing for R53 and R56 MINI, designed to produce high down force, low drag, and increased tire grip. The wind tunnel tested proprietary 3D design uses 2 different planes of aero foils to increase down force by optimally using the air moving over the roof and down the sides of the car. Wind tunnel testing proved 213lbs of down force over stock MINI wing at 130mph with drag equal to less than 1 side mirror. Mounts and stanchions are designed to position the wing for most efficient use of air over and around the car. Adjustable angle of attack provides ability to adjust the wing foil for all types of tracks and driver needs. Best results are found between 2 and 5 degrees angle of attack. All mounting hardware is included for installation.
Specs:
63” wide carbon fiber wing
Downforce Adjustable
Aluminum mounts
Weight 8 lb total with mounting hardware.
We compete with them on our race cars, and win!
Link: http://www.sneed4speed.com/mini-r53-...bon-rear-wing/
Attached Thumbnails SneedSpeed Mini R53 and R56 Race Wing-aero1.jpg   SneedSpeed Mini R53 and R56 Race Wing-wing2.jpg   SneedSpeed Mini R53 and R56 Race Wing-wing.jpg   SneedSpeed Mini R53 and R56 Race Wing-mini-cooper.jpg   SneedSpeed Mini R53 and R56 Race Wing-minibot.jpg
