Mini R56 Oil Cooler Kit
NOW FITS MINIs with larger aftermarket front mount intercoolers!! No more bumper support trimming required on most cars either!
Oil Cooler - Keep your engine oil cool on the street or track and protect your engine investment with a Sneed Speed Oil Cooler kit. The kit is built with a water jet cut billet aluminum adapter plate, aluminum aircraft fittings, aircraft hose rated to 300psi and a fin and tube oil cooler unit for max cooling capacity at low weight. Each kit is designed for each make and model of car to provide max cooling and easy installation. We’ve logged thousands of track and street miles on our Sneed Speed MINI Cooper S testing these oil coolers with no issues! Our kit helps reduce oil temperatures, reduce power loss from excessive oil temps and reduces stress on oil which leads to engine failure from oil break down, plus it adds 1 quart of capacity. Reduces peak engine oil temp by 40 degrees. Engine oil will still warm up to normal operating temp during normal driving, even in the winter.
Spec Sheet:
Heavy Duty fin and tube oil cooler unit
Laser cut billet aluminum adapter plate
Aluminum aircraft fittings
Heavy Duty kevlar braided hose in Push Lock (Black hose) rated at 250PSI or Stainless Steel rated at over 300PSI
Mounting hardware
Insights:
Uses stock oil filter
Weight 5 lbs.
R56 = 2007 and up.
Spec Sheet:
Mounting hardware
Insights:
Weight 5 lbs.
R56 = 2007 and up.
