SneedSpeed Mini R53 Big Bore Kit 1.7 Liter
The 1.7 liter big bore kit is here! There's no substitute for displacement. The Sneed big bore kit maintains the factory rod/stroke ratio for long engine life and high revs unlike stroker kits that reduce the rod/stroke ratio causing additional wear on the cylinder walls and pistons, plus reducing the max engine rpm.
Kit includes big bore pistons, rings, wrist pins and matching MLS head gasket. Kit can be used with any stock length connecting rod.
