SneedSpeed Mini R53 Ported Intake Manifold
Old Nov 7, 2016 | 08:03 AM
SneedSpeed's Avatar
SneedSpeed
R53 Super Cooper Intake Manifold. This manifold is design to prevent the unequal cylinder air/fuel distrubtion that causes engine failure by adding plenum volume to the manifold. The intake is ported, polished and the plenum volume increased by adding additional aluminum to the intake manifold itself. Designed to be used with the stock ECU, wiring, sensors and throttle body. It is a direct replacment for the stock intake manifold and can be used on stock (non tuned) cars. There is a 200.00 core charge on the intake manifold that will be refunded to you when your good core intake is recieved by us. You can also send in your intake to avoid the core charge, build time is 1-2 weeks.
Attached Thumbnails SneedSpeed Mini R53 Ported Intake Manifold-intake-manifold.jpg   SneedSpeed Mini R53 Ported Intake Manifold-intake-manifold1.jpg   SneedSpeed Mini R53 Ported Intake Manifold-intake-manifold2.jpg   SneedSpeed Mini R53 Ported Intake Manifold-intake-manifold3.jpg   SneedSpeed Mini R53 Ported Intake Manifold-intake-manifold4.jpg
