SneedSpeed Mini R53 Oil Cooler Kit
Keep your engine oil cool on the street or track and protect your engine investment with a Sneed Speed Oil Cooler kit. The kit is built with a water jet cut billet aluminum adapter plate, aluminum aircraft fittings, aircraft hose and a fin and tube oil cooler unit for max cooling capacity at low weight. Each kit is designed for each make and model of car to provide max cooling and easy installation. We’ve logged thousands of track and street miles on our Sneed Speed MINI Cooper S testing these oil coolers with no issues! Our kit helps reduce oil temperatures, reduce power loss from excessive oil temps and reduces stress on oil which leads to engine failure from oil break down, plus it adds 1 quart of capacity. Reduces peak engine oil temp by 40 degrees. Engine oil will still warm up to normal operating temp during normal driving, even in the winter.
WHClubman
Aug 10, 2016 07:13 PM
Nicbay350
Aug 10, 2016 08:18 AM
