DINANTRONICS Tuner Now Available || ECS Geomet Performance Rotors
Old 09-27-2016, 08:50 AM
ECSTuning is offline
Received 1,966 Likes on 1,766 Posts
MINI F55/F56 Dinantronics Sport Performance Tuner
This boost controller was designed from the beginning to be easily installed and even easier to use. It plugs into a sensor and uses the factory DME to re-map boost, timing, and fuel maps. Changes can be made via Bluetooth, allowing you to use your smartphone to turn boost up for max performance or down for conservative driving. The app contains a live boost monitor that streams data in real time.
Up to 30Hp and 40lb/ft gain with just this high tech module!
Pick up a plate frame or front plate while you are at it to show your Dinan support.
Big gains in a small package
Fits:
F56 / F55 MINI Cooper /S/JCW (2014+)
Click HERE
ECS Tuning MINI Cooper GEOMET® Rotors
GEOMET® premium brake rotors start with quality materials and precision ECS machining. That would be enough for most of us, but it is only the beginning.
To prevent brake pad deposits for better braking, select a slotted ECS GEOMET® rotor. Slotting cleans the pads by moving water, gases, and contaminants away from the pad/rotor contact surface.
To prevent rust pitting and corrosion damage, ECS GEOMET® rotors are bathed in a special water-based solution, then heated to cure the coating and remove all oil residue remaining from the manufacturing process.
SEE FITMENTS Below
Gen1
Fits:
R50 MINI Cooper (2002-7/2006)
R53 MINI Cooper S / JCW (2002-7/2006)
R52 MINI Cooper Convertible /S/JCW (2005-7/2006)
Click HERE
Fits:
R50 MINI Cooper (7/2006+)
R52 MINI Cooper Convertible /S/JCW (7/2006-2008)
R53 MINI Cooper S/JCW (7/2006+)
Click HERE
Gen 2
Fits: ( NON S )
R56 MINI Cooper (2007+)
R55 MINI Cooper Clubman (2008+)
R57 MINI Cooper Convertible (2009+)
R58 MINI Coupe' (2012+)
R59 MINI Roadster (2012+)
Click HERE
Fits:
R56 MINI Cooper S / JCW (2007+)
R55 MINI Cooper Clubman S / JCW (2008+)
R57 MINI Cooper Convertible S / JCW (2009+)
R58 MINI Coupe' S / JCW (2012+)
R59 MINI Roadster S / JCW (2012+)
Click HERE
Fits: ( NON S / SX ( ALL4 ))
R60 MINI Countryman 2011+
R61 MINI Paceman 2013+
Click HERE
Fits:
R60 MINI Countryman S/SX(ALL4) 2011+
R61 MINI Paceman S/SX(ALL4) 2013+
Click HERE
TJANK
07-31-2019 06:23 AM
TJANK
08-10-2016 11:46 AM
08-05-2016 02:24 PM
08-05-2016 02:22 PM
08-05-2016 02:05 PM
Quick Reply: DINANTRONICS Tuner Now Available || ECS Geomet Performance Rotors
