AWE Tuning F5X S-FLO Carbon Intake. Available Now.
Old Mar 21, 2016 | 12:35 PM
Josh/AWE's Avatar
Josh/AWE
Presenting the AWE Tuning MINI F5X S-FLO Carbon Intake. Increased turbo spool and diverter sounds, unlocked performance. Let’s motor, harder:
  • Max gains of 9 hp and 10 ft-lbs of torque to the crank
  • 30% increase in airflow over stock
  • Carbon fiber heat shield design keeps things cool while unleashing intake sounds
  • Composed of 3k, 2x2 twill carbon fiber with a UV-stabilized resin
  • Features AWE Tuning’s durable and washable S-FLO Filter
  • Carbon fiber construction lowers thermal conductivity versus metal heat shields
  • Perfect integration with OEM inlet ducting to utilize high pressure air from front of vehicle
  • Retains factory mounting and MAF location for trouble-free operation and OE-like fit
  • Designed, engineered and tested in-house at AWE Tuning
  • No Check Engine Light Guarantee
  • Perfect Fitment - Guaranteed
The MINI F5X S-FLO Carbon Intake:
Boasting a carbon fiber heat shield design composed of 3k, 2x2 twill carbon fiber, the MINI F5X S-FLO Carbon Intake delivers a significant dose of respiratory refinement to the 2.0T engine. The engineered design allows high pressure air sourced from the leading edge of the vehicle to stay cool, while also uncorking turbo and diverter valve volume.
Utilizing factory intake and MAF mounting locations, the AWE Tuning MINI S-FLO is engineered to mate seamlessly to the factory air inlet pipe -- perfect fitment and check engine light-free operation. Guaranteed.
The S-FLO Filter:
Sporting a proprietary design, the AWE Tuning S-FLO Filter’s increased flow rate helps to unlock 9 hp and 10 ft-lbs of torque at the crank, and provide a notable increase in throttle response.
The S-FLO Filter is washable and comes pre-oiled.
What’s in the box:
The AWE Tuning F5X S-FLO Carbon Intake includes the carbon fiber airbox, the AWE Tuning S-FLO Filter, and all necessary hardware.
Video:
Images:
Data:
Availability:
F5X S-FLO Carbon Intakes are available direct or through your favorite AWE Tuning Dealer. Click here to be taken to our dealer map.
Questions? Hit me here or directly via email! Let's chat.
kinger62
Mar 13, 2016 06:33 PM
cspec
Tires, Wheels, & Brakes
11
Feb 25, 2016 03:16 PM
dotdotcom
Feb 24, 2016 02:30 PM
Rjlopez0821
Feb 21, 2016 02:22 PM
