:: ECS Tuning :: ECS Wheel Spacers }{ F56 / F55 Style DRL LED Headlights ( R56+)
Old Jun 11, 2015 | 08:28 AM
MINI R50/R52/R53 25+30mm ECS Wheel Spacers ( 2002-7/2006 )
Don't let conventional spacer options leave you feeling down and out. ECS bolt-on wheel spacers are the right way to push your wheels out to the fenders.
These precision machined, 6061-T6 anodized black aluminum spacers have 4140 integral steel threads. Forget the perils of extra-long wheel bolts; these come complete with all the low profile bolts needed to properly torque the spacers to the hub in factory looking black and your wheels to the spacers.
ECS bolt-on spacers will have your car sitting just wide.
Space Out
Fits:
R50 MINI Cooper (2002-7/2006)
R52 MINI Cooper Convertible / S / JCW(2005-7/2006)
R53 MINI Cooper S / JCW (2002-7/2006)
Click HERE For spacer kits
MINI R50/R52/R53 25+30mm ECS Wheel Spacers ( 7/2006+)
Space Out
Fits:
R50 MINI Cooper (7/2006+)
R52 MINI Cooper Convertible /S/JCW (7/2006-2008)
R53 MINI Cooper S / JCW (7/2006+)
Click HERE for spacer kits
MINI R55/R56/R57 Projector Blackout LED DRL Headlights
ECS now offers Blackout LED Daylight Running Lights for your MINI R55/R56/R57, designed to look like the later Gen 3 F56/F55 MINI OEM HID Projector headlights.
Sets are available both for cars equipped with factory HID (Xenon) headlights and those equipped with factory Halogen headlights.
These Genuine MINI like style Spyder Brand Headlights feature high impact plastic lenses with a black housing, and LED DRL and black exterior design.
(Halogens) H9 Projector bulbs and ( Halogen or Xenon ) PY21 Turn signal bulbs are included.
Black is Back
Fits:
R56 MINI Cooper /S/JCW (2007-2013)
R55 MINI Clubman /S/JCW (2008-2014)
R57 MINI CooperConvertible /S/JCW (2009+)
* Halogen projector for Halogen headlights & Xenon Projector for Xenon Headlights
Click HERE For DRL LED Headlight kits
MINI R58/R59 Projector Blackout LED DRL Headlights
ECS now offers Blackout LED Daylight Running Lights for your MINI R58/R59, designed to look like the later Gen 3 F56/F55 MINI OEM HID Projector headlights.
The Spyder headlights feature high impact plastic lenses with a black housing, and LED DRL and a black exterior.
(Halogen) H9 Projector bulbs and (Halogen or Xenon) PY21 Turn signal bulbs are included.
Black is Back
Fits:
R58 MINI Coupe' / S / JCW (2012+)
R59 MINI Roadster / S / JCW (2012+)
Click HERE For LED DRL Headlight Kit
R50 R52 R53 MINI Depo Blackout Headlights
Depo now offers Blackout Halogen Headlight Housings with Chrome rings for your MINI R50 R52 R53.
The DOT/SAE compliant housings are finished in classic black matte with sophisticated chrome ring surrounds.
These direct-fit headlights are designed to easily replace your factory units in less than an hour.
The headlight design mimics the later Gen 1 MINI Halogen headlights, ensuring that this styling upgrade looks consistent with the rest of the car.
Two H7 Bulbs are required per light housing.
A Tasteful Upgrade
Fits:
R50 MINI Cooper (7/2004-2006)
R53 MINI Cooper S / JCW (7/2004-2006)
R52 MINI Cooper Convertible / S / JCW (2005-2008)
*without headlight washers
Click HERE For Depo blackout headlights
MINI R56 R57 Depo Clear/Smoked Tail Light Sets
ECS is now offering the '07-10' style Clear or Smoked Tail Light Sets for your MINI R56/R57.
The Depo units come with clear turn signals and either Smoked or Clear lenses. Both sets light up red on the brake lights and running lights.
The kits come with bulbs pre-installed, and are a simple plug-and-play styling upgrade for your MINI.
Plug & Play
Fits:
R56 MINI Cooper /S/JCW (2007-2010)
R57 MINI Cooper Convertible /S/JCW (2009-2010)
Click HERE For Depo taillights
R55-R59 25+30mm ECS Wheel Spacers
ECS bolt-on spacers for your MINI R55-R59 let you dial in the ideal stance.
Space Out
Fits:
R55 MINI Cooper Clubman /S/JCW (2008+)
R56 MINI Cooper /S/JCW (2007+)
R57 MINI Cooper Convertible /S/JCW (2009+)
R58 MINI Cooper Coupe' /S/JCW (2012+)
R59 MINI Cooper Roadter /S/JCW (2012+)
Click HERE For ECS wheel spacers
R50 R52 R53 MINI Schroth Quick Fit Harness
A frequent dilemma when fitting an upgraded seat belt to track-prepared street cars is how to balance the needs of daily driving with the demands of performance driving.
A dedicated track-day setup is typically impractical, while running without a substantial harness forces the driver to use the steering wheel to hold themselves in place.
Schroth Racing Quick Fit Harnesses are fully reversible and anchor to the factory seat belt pre-tensioner, allowing the airbags to deploy as the MINI engineers intended.
Both left (driver) and right (passenger) harnesses are available.
Track Ready!
Fits:
R50 MINI Cooper (2001-2006)
R52 MINI Cooper Convertible /S/JCW (2005-2008)
R53 MINI Cooper S / JCW (2002-2006)
Click HERE For Schroth Harnesses
R50 R52 R53 MINI Cooper ECS Wheel Spacer Kits ( 2002-7/2006 )
3mm - 20mm sizes
Wheel spacers are a great way to get the look you want from your wheels.
Set up a more aggressive stance by pushing the wheels out from the body. The hubcentric units can also serve as a cure for wheel rubbing when utilizing an aftermarket suspension setup.
ECS offers a wide variety of sizes to give you the exact look you need - choose the ideal stance for your specific needs and tastes.
Every ECS spacer is made from a high quality aluminum to keep weight to a minimum and effectively resist corrosion.
Stance Out!
Fits:
Click HERE For wheel spacers kits
R50 R52 R53 MINI Cooper (7/2006+) ECS Wheel Spacer Kits
3mm-20mm sizes
Stance Out!
Fits:
Accessory Products
Aug 10, 2015 01:35 PM
Aug 10, 2015 01:33 PM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
