:: ECS Tuning :: ECS Wheel Spacers Kits & STP Gen 2 || NM Engineering Now @ ECS
Old Mar 18, 2015 | 08:44 AM
MINI Gen 1 '02-7/'06 ECS 25mm & 30mm Wheel Spacers Kits
Don't let conventional spacer options leave you feeling down and out. ECS bolt-on wheel spacers are the right way to push your wheels out to the fenders.
These precision machined, 6061-T6 anodized black aluminum spacers have 4140 integral steel threads. Forget the perils of extra-long wheel bolts; these come complete with all the low profile bolts needed to properly torque the spacers to the hub in factory looking black and your wheels to the spacers.
ECS bolt-on spacers will have your car sitting just wide.
Space Out
Fits:
R50 MINI Cooper (2002-7/2006)
R52 MINI Cooper Convertible / S / JCW(2005-7/2006)
R53 MINI Cooper S / JCW (2002-7/2006)
Click HERE for Wheels spacers
MINI Gen 2 R56+ ECS Wheel Spacers
Don't let conventional spacer options leave you feeling down & out. ECS bolt-on wheel spacers are the right way to push your wheels out to the fenders.
These precision-machined, 6061-T6 anodized black aluminum spacers have 4140 integral steel threads. Forget the perils of sourcing the correct extra-long wheel bolts; each ECS Spacer Kit includes the required longer bolts in factory-look black for safe & precise fitment.
Additionally, the hubcentric design centers the spacer perfectly on the wheel hub, eliminating the shaking & wobbling at speed characteristic of inferior spacers.
The Space Between
Fits:
R55 MINI Cooper Clubman /S/JCW (2008+)
R56 MINI Cooper /S/JCW (2007+)
R57 MINI Cooper Convertible /S/JCW (2009+)
R58 MINI Cooper Coupe' /S/JCW (2012+)
R59 MINI Cooper Roadter /S/JCW (2012+)
Click HERE for wheel spacers kits
MINI R56 S/JCW NM Engineering Performance Products
NM Engineering's primary goal is to improve the driver's motoring experience without changing the essence of what makes MINI a MINI.
Now available through ECS Tuning, browse through the stunning catalog of NM drivetrain, powertrain, and aesthetic upgrades for your MINI R56 S/JCW.
The NM Hi-Flow Induction Kit comes in three colors, all increasing air flow to your engine for better throttle response and power. NM Engine Torque Arm Inserts better secure your powertrain for a more connected driveline.
NM structural enhancements include a 22mm Adjustable Sway Bar and NM Tie Bar.
Authentic NM
Fits: N14 engines
R56 MINI Cooper S(2007-2010)
R56 MINI Cooper JCW (2009-2012)
Click HERE For NM Engineering
MINI F56 Base/S NM Engineering Performance Products
Now available through ECS Tuning, browse through the stunning catalog of NM drivetrain, powertrain, and aesthetic upgrades for your MINI F56 Base/S.
The NM Hi-Flow Induction Kit comes in three colors, all increasing air flow to your engine for better throttle response and power. NM also offers an array of beautiful satin black, gunmetal, and satin gunmetal wheels.
Authentic NM
Fits:
F56 MINI Cooper (2014+)
F56 MINI Cooper S (2014+)
Click HERE here for NM Engineering
MINI R60/R61 S/SX/JCW ECS Exact-Fit Brake Lines
ECS Exact-Fit stainless reinforced brake lines provide more confident and dependable stopping by maintaining consistent brake pressure, long lasting corrosion resistance, and increased protection from failure.
Even when new, factory style fabric mesh lined rubber hoses are prone to expansion under the pressure of hard braking, whether it be highway panic stops or threshold braking at the track. Our lines are braided with stainless steel mesh, affording expansion resistance. This resistance to expansion creates a firmer pedal, and more direct pedal feel.
Stopping Never Looked So Good
Fits:
R60 MINI Countryman /S/SX/JCW (2011+)
R61 MINI Paceman /S/SX/JCW (2013+)
Click HERE for the Brake Lines
MINI R56 ST XTA Performance Coilovers
The lowered ride height achieved by upgrading your factory suspension is a consequence of the modification, not its purpose.
The ST-line Performance Coilovers utilize tempered high-strength springs, hardened chrome piston rods, and galvanized zinc-plated strut housings - a consequence of which is a powerful, aggressive stance. But the enduring value of this arrangement lay in its durability, reliability, and strict adherence to precise engineering.
Featuring adjustable damping and aluminum adjustable front camber plates, average lowering is 1.2-2.2"F, 1.2-2.2"R.
Fits:
R56 MINI Cooper /S/JCW (2007-2013)
Click HERE for ST XTA
MINI R55/R56/R57 ECS Strut Tower Plates
The strut tower for the MINI Cooper was designed to adequately support the stresses and forces encountered during typical daily driving.
Aging models or vehicles that are routinely pushed past the limitations of the chassis oftentimes experience strut tower deformation, compromising the crisp and responsive handling that defines every MINI.
Machined from 15mm thick 6061-T6 aluminum, ECS Strut Tower Plate Kits eliminate the prospect of tower mushrooming while improving chassis rigidity for your MINI R55/R56/R57 Cooper.
ECS - Smart and Simple
Fits:
R56 MINI Cooper/S/JCW (2007+)
R55 MINI Clubman /S/JCW (2008+)
R57 MINI Cooper Convetible /S/JCW (2009+)
Click HERE for ECS STP Gen 2
MINI R52 Ziza LED Interior Kits
LED bulbs are a stunning revolution for the world of automotive lighting and it’s easy to see why.
LED bulbs are vastly superior to stock bulbs, as they have a higher light output and are far more efficient. Installing these Ziza LED bulbs is a breeze, as you just pop out the old bulb and insert a new one, giving you incredible lighting in a matter of moments.
This kit will transform your entire MINI R52 interior to bright white light that modernizes the look of your car unlike any other modification.
Stunning!
Fits:
R52 MINI Cooper Convertible / S / JCW (2005-2008)
Click HERE for Convertible Ziza LED Kits
Aug 10, 2015 02:03 PM
Aug 10, 2015 01:59 PM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
