:: ECS Tuning :: Forge N18 BOV Kit [] ST X Suspension Savings [] Pierburg Vacuum Pump
Old Nov 24, 2014 | 01:02 PM
R58 R59 N18 Forge Blowoff Valve Kits
Ready to blow off a little steam? Get Forge under your hood.
Stock diverter valves just can't handle performance upgrades. Add a little boost and they get all weak in the knees and go to pieces.
Forge knows this. That's why they've engineered boost-hardy blow off and diverter valves tough enough to take the pressure without blowing their lids.
Aluminum housing. Faster Response. Works and plays well with engine management systems.
Fits:
N18 Engines
R58 MINI Coupe' JCW (2013+)
R58 MINI Coupe' S (2012+)
R59 MINI Roadster JCW (2013+)
R59 MINI Roadster S (2012+)
Click HERE for FORGE
MINI R50/R52/R53 Cooper ST X Coilovers
Changing the suspension setup on a refined European car often times feels like meddling with perfection. With an advanced, highly wrought coilover system, you can be confident your addition is a reliable improvement.
ST coilovers by KW are made of high grade, galvanized steel, and come with a 5 year limited warranty. With engineering tailored specifically to your MINI, preset damping and height adjustability provide the perfect balance between performance and ride comfort.
ST - Smart Technology; Street Tough
Fits:
R50 MINI Cooper (2002-2006)
R53 MINI Cooper S / JCW (2002-2006)
R52 MINI Cooper Convertible (2005-2008)
Click HERE for the STX kit
MINI R56 Cooper ST X Coilovers
Changing the suspension setup on a refined German car often times feels like meddling with perfection. With an advanced, highly wrought coilover system, you can be confident your addition is a reliable improvement.
Fits:
R56 MINI Cooper S/JCW (2007+)
Click HERE For the STX
R50/R52/R53 MINI Cooper FK Universal Car Cover
Keep dust, dirt and other elements off your car during indoor storage with this new single layer nylon universal car cover from FK.
Blue sides and black and white checkered center gives your car great looks, even when you can't see it.
This particular cover is intended for indoor use, and uses high-quality materials for exceptional protection of your MINI.
Got You Covered.
Fits: Gen 1
Click HERE for FK car covers.
MINI R60 R61 Oil Service Kits
The best oil for your MINI? Clean oil. Regular oil changes with a quality filter cartridge are cheap insurance against costly breakdowns, and the best way to keep your MINI healthy.
Now you can perform this essential service yourself and save big with MINI oil change kits that contain an OEM filter cartridge with drain plug & crush washer, plus your choice of name brand engine oils that meet BMW LL-98 and BMW LL-01 standards.
Spend a little up front and head off major repairs, down the road.
Drain Your Oil, Not Your Wallet
Fits:
R60 MINI Countryman /S/SX/JCW (2011+)
R61 MINI Paceman /S/SX/JCW (2013+)
Click HERE for oil change kits
R56/57 MINI Cooper FK Universal Car Cover
Got You Covered.
Fits:
R56 MINI Cooper / S / JCW (2007+)
R57 MINI Cooper Convertible / S / JCW (2009+)
MINI R55 R57 ST X Performance Coilovers
Fits MINI:
R55 Clubman /S/JCW (2008+)
R57 Cooper Convertible /S/JCW (2009+)
Click HERE for STX kits
MINI R56 ST X Performance Coilover
Fits MINI:
R56 Cooper Base (2007-2013)
Click HERE for the STX kits
MINI Cooper S/JCW R55 R56 R57 N14 Vacuum Pump
If the brakes in your MINI have begun to feel a little soft, or stopping isn't as precise and powerful as they used to be, the problem may be your vacuum pump.
This is used for the wastegate actuation on the turbo.
The vacuum pump assists the power braking system in providing ample braking pressure.
ECS now offers a Vacuum Pump from Pierburg for your R55/R56/R57 N14-powered Cooper S/JCW.
*N14 engines*
R56 MINI Cooper S (2007-2010) JCW (2009-2012)
R55 MINI Clubman S (2008-2010) JCW (2009-2012)
R57 MINI Cooper Convertible S (2009-2010) JCW (2009-2012)
Click HERE for the Vacuum pump
MINI R58/R59 Coupe/Roadster N14 Vacuum Pump
ECS now offers a Vacuum Pump from Pierburg for your R58/R59 N14-powered Coupe/Roadster JCW.
Fits:
R58 MINI Coupe' JCW (2012)
R59 MINI Roadster JCW (2012)
*N14 engines*
Aug 12, 2015 01:24 PM
Aug 10, 2015 02:03 PM
Aug 10, 2015 01:59 PM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
