:: ECS Tuning :: "Blackline" Taillights // Ziza R58/R59 LEDs // South Bend Clutch Kit
MINI Cooper R56/R57/R58/R59 Black Line Taillights
The Genuine MINI 'Black Line' style Taillights bring a subdued black/smoked look and a subtle touch of black to the red housings.
The kit includes both the left and right side rear taillights, allowing you to refresh the back of your MINI in a single kit.
Note: Matching 'black line' headlight and taillight trims are also available to complete the transformation.
Genuine MINI Style
Fits:
R56 MINI Cooper /S/JCW (8/2010+)
R57 MINI Cooper Convertible /S/JCW (8/2010+)
R58 MINI Cooper Coupe' /S/JCW (2012+)
R59 MINI Cooper Roadster /S/JCW (2012+)
[B]Click HERE for the MINI Black Line Taillights
MINI Cooper R50 R52 R53 Wheel Hanger
Our aluminum wheel hanger makes it easy to remove and install wheels. Just thread the hanger stud into a wheel bolt hole and hang the wheel safely while you rotate tires or remove them for service or vehicle repair. It's also great for keeping wheel bolt holes aligned on cars with spacers.
Our improved hanger is made of 6061 aluminum, anodized for hardness and good looks. The knurled, non-slip handle has a drilled hole so you can hang it on a pegboard hook in your garage.
Better still, order two: one for your garage and another for the emergency tool kit in your trunk.
Fits:
R50 MINI Cooper (2002-7/2006)
R52 MINI Cooper Convertible /S/JCW (2005-7/2006)
R53 MINI Cooper S/JCW (2002-7/2006)
Click HERE for Schwaben Wheel Hanger information.
MINI R58 R59 Ziza LED Interior Kit
LED bulbs are a stunning revolution for the world of automotive lighting and it’s easy to see why.
LED bulbs are vastly superior to stock bulbs, as they have a higher light output and are far more efficient. Installing these Ziza LED bulbs is a breeze, as you just pop out the old bulb and insert a new one, giving you incredible lighting in a matter of moments.
This kit will transform your entire interior to bright white light.
Fits:
R58 MINI Coupe' /S/JCW (2012+)
R59 MINI Roadster /S/JCW (2012+)
Click HERE for Ziza LED Kits for more information.
MINI R52 Convertible LED Third Stop Light " Clear "
Bring a tasteful European design element to the rear of your R52 Convertible with the Genuine MINI Clear LED Third Stop Light.
The clear lens with red LEDs is a direct-fit, snap in place part, coupled with the ease of plug-and-play installation.
The lens mounts below the rear glass on convertible models, and lights up red under braking.
Fits:
R52 MINI Cooper Convertible /S/JCW (2005-2008)
Click HERE for MINI Clear stop light or for more information.
R50 GEN1 South Bend Clutch Kit
South Bend Clutch has been manufacturing performance and street clutches for 40+ years. This dedication to product specialization makes today's South Bend products better refined compared to larger distributors.
Two Stages & Two driving styles styles are accommodated for, allowing you to carefully choose the exact clutch for your needs.
From daily driven to track cars they have you covered.
So Clutch
Fits MINI:
R50 MINI Cooper (2002-7/2004)
Click HERE for South Bend Clutch Kits or for more information.
R50/R52 GEN1 South Bend Clutch Kit
Two Stages & Two driving styles are accommodated for, allowing you to carefully choose the exact clutch for your needs.
So Clutch
Fits:
R50 MINI Cooper (7/2004-2006)
R52 MINI Cooper Convertible (2005-2008)
Aug 12, 2015 01:24 PM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
