MINI Cooper S R52/R53 Gates Water Pump
Old May 28, 2014 | 04:58 PM
Emnotek's Avatar
Emnotek
In Stock Ready to Ship!
A new water pump for your Gen1 MINI Cooper S is a must whether you're performing standard maintenance or rebuilding your motor. This is a direct replacement for your stock pump and includes all the necessary gaskets and hardware saving you the hassle of multiple trips to the dealer or messy leaks due to poor seals. The quality-forged housing is specially formed to ensure maximum coolant flow for your MINI Cooper. The precision balanced impeller increases water flow, and extends seal and bearing life. The no-sealant-required gasket allows for fast, easy installation. The shaft and hub are precisely ground to exactly fit your MINI's stock fan clutches.
Cereall
Sep 5, 2019 06:05 PM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
kwijmbo
Aug 5, 2015 09:00 PM
