Replace Your Spark Plug Tube Grommets & Valve Cover Gasket! by Pelican Parts
Over time, the grommets that seal the spark plug tubes to the valve cover can harden up due to heat and oil penetration. This can result in oil leaking into the spark plug tubes and also idle problems with the fuel injection due to vacuum leaks. Eventually, oil filling up in the spark plug tubes can reduce performance or even cause the plugs to stop firing. If you go to change your spark plugs and there is oil all over the plugs, the seals are leaking and must be replaced.
We have new valve cover gaskets & spark plug tube grommets in stock ready to ship! Click here to shop for Cooper & Cooper S Valve Cover Gaskets & Spark Plug Tube Grommets through '08.
Check out install instructions HERE
Let us know how it goes!
888.280.7799 | 6am - 5pm PST
09R56
Nov 16, 2022 10:49 AM
silence2-38554
98
Sep 21, 2016 02:52 PM
