New Oil Catch Can Available
Old Jul 26, 2012 | 07:44 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Way Motor Works is excited to have the newest and best NM Oil Catch Can available for R55 R56 R57 R58 R59 MINI Cooper S with N14 Engine. The new NM catch can has a multi stage method of condensing the oil out of the crankcase vapor and preventing it from entering the intake. As the oil enters the catch can it hits a wall causing much of the oil to condense, then the air passes into the bottom of the can through smaller notches. There it goes through a stainless steel mesh collecting even more oil. After that it finally passes through machined holes like a screen before it exits the can.
If that wasn't enough look at the perfect aluminum machined fittings, and ideal mounting bracket to hold it.
With the direct injection a good oil catch can will cut down on carbon buildup and save you from costly repairs from buildup.
CardinalsRule
Jun 11, 2016 04:34 PM
molala
Oct 2, 2015 01:53 PM
David Eric Rosenberg
R57 :: Cabrio Talk (2009+)
Sep 10, 2015 12:34 PM
Sep 3, 2015 03:01 PM
Sep 2, 2015 09:05 AM
