Winterize Your Mini!
Old Oct 18, 2011 | 02:21 PM
Mini Mania's Avatar
Mini Mania's 12 point Winterization Checklist
  • Tune up the motor. (Air, Oil and Fuel filters, including new spark plugs, ignition cap, rotor and wires. Ignition system needs to be in top shape to battle the cold.)
  • Check the anti-freeze. (Only fill with recommended brand anti-freeze, make sure to check your owners manual for proper anti-freeze type.)
  • Check all other fluid levels and fill as needed. (Brake Fluid, Mineral Oil, etc.)
  • Fill wiper fluid reservoir with de-icing solution.
  • Check the battery. (You can load test your battery at any local auto parts store.)
  • Check the tread and air pressure of tires. (You want to insure good grip on the slick roads, also good for the gas mileage of your vehicle.)
  • Inspect the brakes. (Quick visual inspection will give you peace of mind driving in cold harsh conditions.)
  • Install good windshield wiper blades. (Good wipers such as Bosch will keep your windsheild free and clear.)
  • Check headlights and signal lights. (A good idea would be to convert your old filament bulbs to the new LED bulbs, these are brighter and last longer.)
  • Check belts and hoses, replace as necessary. (Any cracks will only get worse in the cold weather, leading to more expensive repairs.)
  • Ensure heater and defroster are in good working condition.
Dec 23, 2015 10:36 AM
ludedude
Aug 10, 2015 07:16 PM
Dashdog
Aug 10, 2015 06:17 AM
Aug 7, 2015 05:56 AM
