ON SALE :: MINI Engine Scan Diagnostic Code Reader (Service Light Scan & Reset)
Old Apr 8, 2009 | 09:54 AM
Emnotek's Avatar
Emnotek
  • Available for all MINIs (2001-2006)
  • This tool has the 16 pin plug for connection under the dash
  • Displays all MINI engine fault codes - helps diagnose exactly what's wrong.
  • Resets the Service Engine Soon Light (Check Engine Light)
  • Resets the Oil service - Inspection lights & service mileage.
  • This is the only MINI specific service tool available on the market (not a generic code reader).
  • Very easy to use. (We offer Free Customer Support if Needed)
  • Includes complete instruction manual and storage case.
Eurosport Design can help you gain a better understanding for your MINI!
These software based MINI Cooper Reset Tools are very easy to use. Simply plug in the tool - it will then display your error codes - use the MINI specific instruction manual /code booklet to look up your error code which will tell you exactly what's wrong with your car - then clear the error code which turns off your check engine or service lights. It's as easy as putting gas in your car!
Has your MINI Cooper ever stalled, been slow to start, idled poorly or hesitated during acceleration? Has the Engine light (also known as the "Check Engine" or "Service Engine Soon" light) come on when everything seemed fine? Have you ever received a costly repair bill and wondered if the repairs and charges were legitimate?
Without the R5/EMX Diagnostic Engine scan-reset tool, you may be forced into accepting what the repair shop tells you and charges you. Wouldn't it be great to know exactly what's wrong before you bring your MINI in for a repair? Or, better yet, if you're handy with tools you can avoid the repair shop altogether- run your own diagnostic and fix the problem yourself! That is, if your car even needs a repair.
What is the Engine light trying to tell me?
The MINI service engine soon light can mean any number of things. Sometimes it's alerting you to the real need for a repair, so the Engine light is something you should never ignore. But quite often it is merely indicating one of the many, simple (top off your coolant, loose gas cap or oil cap) type problems. Imagine paying a hundred dollars to a repair shop to tighten your radiator cap and reset the Engine light. Without the R5/EMX, you're stuck staring at your Engine light until you're in the mood to see the mechanic who can reset it.
Routine Maintenance Lights!
As an added benefit, the R5/EMX includes the ability to reset the oilservice and inspection, routine maintenance lights, and the maintenance mileage count-down indicator. Considering that an oilservice for a MINI can sometimes equal the price of the R5/EMX, this feature alone is worth the price of the R5/EMX.
Indispensable for Mechanics and Mini owners:
  • Compact Size. Easily fits in glove compartment.
  • Very Easy to Use. As easy as pumping your gas.
  • Inexpensive
  • Available for all MINI from 2001 to 2006 (Cooper and Cooper S)
  • Durable Enough to Withstand Daily use by Professional Mechanics.
According to our toughest critics (mechanics), we have succeeded with flying colors!
MINI Cooper Engine Scanner
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
