Mini Mania Classic Newsletter 8-22-08
Old Aug 22, 2008 | 03:27 PM
Mini Mania's Avatar
Mini Mania Overhauled?!! Check out our new look!
We've redesigned our website with a new look, new menu system, and new search options to make your shopping experience even better!
http://www.minimania.com/home.cfm
Featured Items:
Metro Turbo Vented Brake Conversion Kit
Metro Turbo Vented Brake conversion kit. Kit comes with all parts required to convert a Drum Brake Mini to Vented discs, using the correct Mini hub uprights. Requires 12" or 13" wheels to fit. Included in kit are hubs,bearings cv joints,swivel pins.brake discs,drive flanges,calipers and the special locating bolts for calipers. plus screws.
Boost your stopping power with this conversion kit!
http://www.minimania.com/web/Item/C-.../InvDetail.cfm
Second Generation Mini Mania Performance Camshaft
The "CAM003" cam has been produced by Mini Mania for well over 20 years and has been used extensively in our 1380cc engines becoming legendary in its own right. It is the ideal road cam for 1275cc or 1380cc, below 5500 rpm the CAM003 produces more power than the 286 profile.
Increase HP and your rpm range with this upgrade!
http://www.minimania.com/web/Item/CAM103S/InvDetail.cfm
Spider Drive Oil Pump
The oil pump with a difference! This pump was designed as a long lasting modern oil pump. The steel backing provides rigidity and improved life expectancy. The two bolt design allows the use of this pump in any block configuration. The drive required for the camshaft is the Spline/star drive!
Update your oil pump today!
http://www.minimania.com/web/Item/CHM140/InvDetail.cfm
Spider Drive Oil Pump Adapter
This Oil Pump adapter is needed if your favorite camsahft has the early design 'star drive' for the pump. This cam was very common in the early Mini Cooper and most of the MG Midgets and Austin Healy Sprites. The oil pump adapter allows you to use one of the modern 'slot drive' oil pumps with any of these early camshafts.
Spider Drive Adapter!
http://www.minimania.com/web/Item/12.../InvDetail.cfm
8.4" Brake Rotors & Pads (pair)
This special Mini Cooper kit includes two 8.4" diameter brake rotors as used on all late model Minis & Mini Coopers with 12 or 13 inch wheels and a set of premium brake pads.
Replace your rotors and pads with this kit!
http://www.minimania.com/web/Item/MM.../InvDetail.cfm
Negative Camber (1.5 Degree) Lower Suspension Arms (pair)
Negative camber on the front of the Mini will make the car handle (& turn) much better than stock. A stock Mini will have as much as 1 degree positive camber (the top of the tire leans out from the car more than from the bottom).
Improve your Minis handling today!
Re-Manufactured Cylinder Head (unleaded fuel)
Re-manufactured cylinder head has been set up for unleaded fuel. All new valves, guides and springs assembled and ready to install on your 1275cc engine!
Lamp Gaskets
Replace your worn-out, dry and crumbling lamp gaskets. We've got one for your Mini!
Browse our gasket selection!
http://www.minimania.com/web/SUBTYPE..._Inventory.cfm
"Twin Point" MPI Mini Parts:
Rover Workshop Manual for Twin Point MPI Models Reprint of the Rover Workshop Manual for all 97 on Twin Point Injected models. Covers models manufactered from VIN SAXXNNAZEBD 134455. The most comprehensive manual for twin point cars currently available. Does not include information on automatics.
Get your copy now!
http://www.minimania.com/web/Item/RC.../InvDetail.cfm
Pre-Owned Air Sensor on Inlet Manifold (Twin Point)
Only one in stock!
http://www.minimania.com/web/Item/U%.../InvDetail.cfm
MPI Fuel Injector
Replace your worn/damaged MPI fuel injector!
Fuel Pressure Regulator - Power Booster Kit Fuel Pressure regulator for Twin Point Minis. If you have a TPI Mini and think you have done a lot to increase HP- then you probably will improve things even further with this high performance fuel pressure regulator!
Boost your MPI Power!
http://www.minimania.com/web/Item/PBVMP1/InvDetail.cfm
Fast Road Camshaft - MPI
Rev Range 1500-6500
Power Increase - 10 BHP Inlet/Exhaust Duration 252 deg/264 deg Inlet/Exhaust Valve Lift .350"8.89mm/.346"8.76mm Full Lift (Inlet ATDC Exhaust BTDC) 110 deg Lift @ TDC Inlet/Exhaust (With Clearance) .046" 1.17mm/.061" 1.55mm Valve Clearance .012" / .30mm .016" / .40mm Increase HP and your rpm range with this upgrade!
http://www.minimania.com/web/Item/MP2/InvDetail.cfm
Featured Articles:
Mini Chassis/VIN Numbers and Commission Numbers (Part 1: 1959 - 1980) The information used to compile the following was taken from factory service parts lists and factory microfiche. Under close scrutiny, there appears to be some conflicts and mistakes in the factory number schemes, but, for the most part, the listings are accurate enough for car identification.
Continue reading...
http://www.minimania.com/web/Display...n/ArticleV.cfm
Gearbox Rebuild
Gearboxes may seem complicated but they are very simple in their construction, and surprisingly easy to put together. The main issues are having the right tools to do the job. So here's a list of what you will need...
Continue reading...
Other Interesting Stuff:
Minis For Sale (private listing)
Listing exerpt - "This is a 1980 Austin Mini 1000 in excellent condition. The engine and transmission are in great working condition with no need for repair or renovation. This car contains so much of the original Mini, I would be willing to say it's a great deal for such authenticity. The interior is completely original. Both front and rear seats are in wonderful condition with zero tears or areas of wear. The carpet is in great condition as well. And get this...no external rusting!"
View This Listing
http://www.minimania.com/web/id/7972...ale_Detail.cfm
View More Listings
http://www.minimania.com/web/OrderNa...4Sale_list.cfm
Get a Mini Mania Visa Card!
Now you can have a credit card that is devoted to your hobby for easy control or you can use it every day for anything you desire. Every time you use your credit card, you will show the special pride of ownership only a British car inspires! Feel the confidence and exhilaration of being behind the wheel of your Mini, in every purchase you make.
Your Mini Mania Visa Card is just a click away!
http://www.minimania.com/web/display...6/ArticleV.cfm
Don't miss any of your Mini Mania email. Add news@minimania.com to your address book!
To unsubscribe, Click Here
http://www.minimania.com/MLStatus.cfm
and change your Mailing List Options. Or simply reply to this email with only the word "remove" in the subject line.
Copyright © 2008 Mini Mania, Inc. 870 Gold Flat Road, Nevada City, California, USA All rights reserved.
Internal Virus Database is out-of-date.
Checked by AVG.
Version: 7.5.518 / Virus Database: 269.21.7/1327 - Release Date: 3/12/2008 1:27 PM
chrisx18240
26
Mar 16, 2022 09:56 AM
Dec 23, 2015 10:36 AM
ludedude
Aug 10, 2015 07:16 PM
Aug 10, 2015 01:59 PM
Dashdog
Aug 10, 2015 06:17 AM
