Attn: Wilwood DP caliper owners!!
Old Apr 1, 2008 | 02:36 PM
toddtce's Avatar
toddtce
If you're an Autocrosser looking for and edge....and who isn't, TCE is going to have a very limited supply of Polymatrix D compound pads for the DynaPro caliper shod Big Brake Kits.
The Poly D pad has not been available for this application previously and may not be again. Supplies will be limited.
Poly D pads are a superior choice for Autocross and other low temperature applications. D pads offer a medim coefficien of friction paired with low to meduim temperature function. Over heat them and they also recover very well without rotor or pad damage. If you've been running BP10 pads and felt the need for a bit more repsonsiveness from your big brake system this is the pad for you. Poly D is not an open track pad either so it's not hard on iron and can be driven on the street.
Available April 17th!
Poly D pads- DP calipers $95
I can speak personally of the value of Polymatrix D compound being the pad of chioce for four wins on Pikes Peak. I've tried other pads and D gives me the feedback I want and the bite I need for trying condtions...
jacobj
Tires, Wheels, & Brakes
Oct 4, 2015 11:49 AM
Ryan Caballo
Sep 4, 2015 12:20 PM
squawSkiBum
Sep 2, 2015 09:56 PM
Ntety
Sep 2, 2015 08:39 PM
elightbo
Sep 2, 2015 08:17 AM
