SSR Comp R wheel Pre-order is on!
There has been a long waited arival, drawing closer each day. Its for this wheel ...
Our wheel will be diffrent - Here is how -
No center caps
No macheined lip
16x6.5 et 44
Sub 11 lbs weight.
$299 each.
You want a set? Who wouln't? This wheel is in very high demand, and now are avaialbe to pre order. Pre ordering guarantees your spot in line, and a set to be yours guaranteed.
Its really easy to do, just go into the
TireRack's MCO Upgrade Garage,
right on MCO's homepage (on the right hand side) Put in the Mini, and what year your car is, next page select type of mini. Then pick wheels, scroll thru untill you get to Comp in 6.5 inch. Procede to checkout.
Its importand to use your upgrade garage, it will allow you to be recognized by TireRack's site, and make shopping easier. It also helps us know that YOU support MCO and Tirerack's sponsorship, and keeps everything rolling smoothly. (BTW - you can even buy tires and wheels for your other cars through the Upgrade Garage)
Call with ANY questions
Alex
_________________
Alex ext 294
800 522 8473
Tire & Wheel forum moderator
www.tirerack.com
alex@tirerack.com
No center caps
No macheined lip
16x6.5 et 44
Sub 11 lbs weight.
$299 each.
Alex
_________________
Alex ext 294
800 522 8473
www.tirerack.com
alex@tirerack.com
Kimolaoha
Dec 5, 2020 09:32 PM
SosoMINI
Nov 22, 2015 03:17 PM
