DDMWorks R56 Race Intake
Old Sep 10, 2007 | 09:27 AM
Dave@ddmworks's Avatar
Dave@ddmworks
Manufacturer
DDMWorks is proud to release our R56 Race Intake System (RIS). The intake comes in two parts, the RAS or Ram Air Scoop which makes use of the non functional hood scoop that was just waiting to be used as an intake source, and the DDMWorks PFB or Pressurized Filter Box. With the complete race system in place, your MINI’s filter is washed with cool pressurized ambient air coming in from the front of the car. The whole system working together insures improved throttle response and maximum power consistently for your MINI.
The DDMWorks RAS (Ram Air Scoop)
The unique shape of the DDMWorks RAS was designed to accelerate the incoming air from the hood scoop and keep the new intake box under pressure forcing even more cold air into the turbo and engine. Two diverters on the back of the RAS direct the air down into the filter, and the RAS seals with the top of our pressurized filter box (PFB) to ensure a cool ambient air supply. We also wanted regular maintenance of the car to be unaffected with the intake installed, so even with the RAS mounted to the bonnet of the car, regular maintenance of your engine is just as easy as stock. Access to the spark plugs, oil filter and oil fill are just like stock. The scoop attaches to the bonnet using existing mounting points so there is no drilling or modifications needed for installation. The RAS can also be purchased separately for use with other intake systems that leave an exposed filter in the back of the engine bay. We learned during our thousands of miles of testing that exposed filters without the RAS in place see good temperatures during light cruise, but during long pulls the temperature of the incoming air continued to climb as the turbo heated the air coming in through the scoop. With the simple addition of the RAS on those intakes, temperatures stayed only a few degrees above ambient, which resulted in better throttle response and more consistent power. The RAS is offered in DDMWorks Stainless steel, or for a more stock appearance black matte powder coat.
Price $199
The DDMWorks PFB (Pressurized Filter Box)
During that intake testing, we learned a lot about what the new turbo MINI. A simple filter attached off of the Air flow meter did a really good job of freeing up the intake on the new R56. In fact this simple intake proved to be a real good bang for the buck. However, we did not want to produce just a good intake, we knew we could do better. So we took the time to seal the intake with a covered box that installs easily over the bottom of your stock intake. With the system in place the RAS seals with the PFB resulting in a pressurized system at speed that eliminates restriction before the turbo like no simple filter intake system can duplicate. It also keeps the air coming into your MINI at ambient, a big plus if you are looking to make consistent power during long full throttle accelerations at the track. The PFB comes with one of our UNI Dual stage foam filters to keep the air clean and clear that is being ingested by your engine. With the Foam filter on you will be able to hear the faint sound of the turbo spooling up and the blow off noise of the bypass valve during shifting. We are also offering the PFB with a K&N filter for those that really want to hear the turbo spool and the bypass valve sounds during shifts. Both filters work equally well, but this way you can tailor the sound of the intake to your tastes. The intake is offered in DDMWorks Stainless Steel or black matte powder coat.
Price $249
The first shipment of these intakes is scheduled for September 28th. All orders that we receive before then will also get complimentary shipping to the continental US. You can give us a call at 864-907-6004 and talk to Ivy to get your order in, or we will have them up on our website by the end of this week.
Thanks to everyone that made this intake possible!
Dave
Attached Thumbnails DDMWorks R56 Race Intake-ddmworks-r56-race-system.jpg   DDMWorks R56 Race Intake-ddmworks-r56-ras.jpg   DDMWorks R56 Race Intake-ddmworks-r56-pfb-with-k-and-n-filter.jpg
Old Sep 10, 2007 | 09:28 AM
Dave@ddmworks
Manufacturer
Some more pictures of the RIS installed
Attached Thumbnails DDMWorks R56 Race Intake-ddmworks-r56-pfb-with-k-and-n-filter2.jpg   DDMWorks R56 Race Intake-ddmworks-r56-pfb-with-uni-foam-filter.jpg   DDMWorks R56 Race Intake-ddmworks-r56-pfb-with-uni-foam-filter2.jpg
W0TM8
Dec 19, 2019 07:50 AM
Hippiehobbit267
Dec 3, 2019 04:22 PM
ebowling
90
Aug 4, 2019 09:15 AM
Mikli
R55 :: Clubman Talk (2008+)
Jun 26, 2019 05:58 AM
Aug 21, 2015 11:25 AM
