NAMOTORSPORTS | Forge Spacer for the R56 Mini Cooper S - NOW SHIPPING
Forge Motorsport is a world leader in turbo products for Volkswagen, Audi, Mini and many other cars. Check out their new R56 Mini Cooper S Spacer below
Forge Motorsport Atmospheric Blow Off Valve Spacer (R56 Cooper S Only) - $69.99 plus shipping - In stock and ready to ship!
This Forge Part Fits:
R56 Mini Cooper S
Product Description:
On the Coopers S turbo, built into the turbocharger housing, is a bypass facility. This allows charge air to be recirculated around the turbo charger from the boost side back to the intake side. This recirculation path is opened and closed by means of an electrical connection from the engine management to a solenoid that is mounted on the turbocharger housing. As you accelerate , the turbo charger vanes are spinning and boost pressure is increased, literally blowing into the engine cylinders. Then when you change gear you take you foot of the accelerator momentarily, select the next gear, and accelerate again. As you take your foot off the accelerator the throttle valve to the engine closes. The problem here is that during this process the turbo is still spinning and the boost pressure that it is producing has no where to go. (This is a bit like putting you hand over a hair dryer so the air cannot get out) What happens at this point is the turbo starts to stall, the spinning vanes slow down (incurring alot of stress) and the boost pressure drops. When you open the throttle valve again by pushing down on the accelerator (demanding more power) the turbo has lost its momentum, boost pressure and there is a pause or a "Lag" before the engine is producing the required power once again. To combat this loss of power and stress on the turbo, a recirculation or diverter valve is used. On the Mini, when the throttle valve closes, the engine management opens the recirculation route around the turbo. This gives the charge air an alternative route and allows the turbocharger to keep spinning so that when you accelerate again there is no "lag" or waiting period. This system works well and is adopted by nearly all vehicle manufacturers on turbo charged petrol engine applications. The only downside to this system is that a turbo chargers produce heat. (The hot air that leaves a turbo is cooled by passing it through an intercooler before it enters the engine. The cooler the air the more power is produced. ) By recirculating the hot air back into the intake side of a turbo the temperatures increase. This is where the Blow Off or Dump valve plays its part. By expelling the charge air to atmosphere rather than recirculating it, you do not increase the intake air temperature but you do allow the turbo to keep spinning. The side effect which is unacceptable to most vehicle manufacturers is the noise of the valve expelling the air. By fitting the FMDVMCS between the existing solenoid and the turbo housing (this involves removing only 3 bolts) the air is re-directed to atmosphere rather than recirculated.
It should be noted that the engine management also uses this valve to decrease engine power when necessary. An example of this is by the (DSC) Dynamic Stability Control system. Although you would not normally hear this occurring, when a blow off adaptor is fitted you may well hear the air being expelled when the DSC operates (going to fast around a bend for example).
Tax:
All Connecticut customers will be charged 6% Connecticut Sales tax.
Shipping:
All orders will be shipping via UPS. If you are interested in expedited shipping, please call us. Also, customers in Hawaii, Alaska, Puerto Rico and Canada will be charged additional shipping fees.
Payment:
We accept all major credit cards and Paypal. All website orders can be done directly through our site http://www.namotorsports.net. Please just click any of the product links above to go directly to our site. Call us toll free at 1-877-NAMOTORS to place your order over the phone.
Hours of Operations:
Monday - Thursday from 10AM to 7PM EST
Friday from 10AM to 5PM EST
Saturday from 10AM to 3 PM EST
Sundays we are closed
Retail Showroom:
Come check out our new 6000 square foot facility in Vernon, Connecticut. Click here for directions.
Our website http://www.namotorsports.net is always open
Contact Info:
Phone: 1-877-NAMOTORS
Email: marc@namotorsports.net
Website: www.namotorsports.net
PM: namotorsports
AIM: NAMtrsprts
MSN: NAMotorsports@msn.com
Yahoo: NAMtrsprts
Any questions, feel free to PM me or call toll free at 1-877-NAMOTORS
phrza81
Oct 10, 2015 11:37 PM
cub4bearindiana
Aug 25, 2015 06:49 PM
Mini'mon
Aug 16, 2015 04:15 PM
