Would I Get Any Rubbing?
hello all,
without lowering my mcs, would i get any rubbing if i use 215-40-18 tires on
43 mm offset rims?
i'm currently running 35's and i really don't like the rough ride. i was told that 40's will help a little.
i know the default profile is 35, but i really don't want to lowere my car.
yet, i still want to close the gap between my tires and my fenders/quarterpanels.
can anyone tell me what i should do?
bbt4
43 mm offset rims?
bbt4
I discussed a similar situation recently and there should be plenty of room for me to run a slightly larger diameter tire.
Speedo and gear ratios will be off from stock a little, but not a major concern to me.
Regardless, your comfort will suffer on 18" rims regardless of a tire switch. Might be worth trying though once you burn down the current tires. . . .
Put the car up on stands. Travle the suspension with a floor jack, all the while articulating the steering wheel. This imitataes any road situation you may encounter. This is your best idea for a safe testfit.
Alex
_________________
Alex ext 294
800 522 8473
Tire & Wheel forum moderator
www.tirerack.com
alex@tirerack.com
Alex
_________________
Alex ext 294
800 522 8473
www.tirerack.com
alex@tirerack.com
Alex,
what you're saying is i'll either have to mount one 40 series tire first then try the jack method you've described earlier, or do the jack method with my existing tire and wheel and observe how much "gap" i have left when my suspension is fully compressed.
let me ask you this, Alex.
from experience, do you think i would get any rubbing?
bbt4
bbt4
With the 40's installed on the car. I think at full travel you may rub, thats why I recomed a test fit.
Alex
>>Alex,
>>bbt4
Alex
>>Alex,
>>bbt4
freeman727
Dec 10, 2017 04:00 AM
wildwestrider
11
Jan 29, 2016 05:06 PM
Amberleigh MacIntyre
R55 :: Clubman Talk (2008+)
Nov 11, 2015 11:59 AM
