15 inch wheels with offset 42?
Old Mar 16, 2007 | 10:42 AM
funracer's Avatar
funracer
I have a set of Kumho MX 205/50-15s on order from my local tire shop for autocross. I am looking at a set of Falken Hanabi 15 inch wheels (11 pounds!) with offset of 42 listed in the wheel specs. Will this combination work and be DSP legal on a 04 JCW MCS?
Thanks for any replies
Funracer
Old Mar 16, 2007 | 02:56 PM
jasonsmf's Avatar
jasonsmf
How wide are those wheels? If they are a 15x7 they might not work without spacers. I think some people get away with a 15x7 +40, I personally have a set of 15x7 +38 and they do not leave much room on the inside.
Jason
Old Mar 16, 2007 | 04:31 PM
funracer's Avatar
funracer
Yes, they are 15x7.
Old Mar 16, 2007 | 10:59 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Funracer
For DSP you can use- any DOT tire and any wheel diameter width and offset. So you are OK.
Normally having less offset would be best and allows for more inner clearance for the rear trailing arm and rear swaybar. Front should fit OK.
If your upgraded rear swaybar is not too wide you should be OK.
From tirerack.com they do list other 15x7" rims with +42mm offset like the ASA EM9/JS5 and that should fit a stock MINI. Other +42mm offset rims:
BBS RGF
Borbet 15x7 and 15x6.5 rims are +40mm offset
Many 15x7 rims have +38mm offset like:
BBS RD
Kosei K1 Racing
Kosei K1 TS (I have these and they work fine with 205/50-15 and with 225/45-15 and lowered suspension).
Some have +35 or 36mm offset like:
BBS RF
BBS RZ
Then watch out that the tire you choose is not too tall and rubs the outer wheel arch plastic. Smaller outer tire diameter sizes like 205/50-15 and 225/45-15 will work best.
Old Mar 17, 2007 | 05:23 AM
Mugami's Avatar
Mugami
Coordinator :: River City Minis
Im running the Hannibals and using 225/45/15, They work fine with no spacers. also my car has been lowered
Old Mar 17, 2007 | 02:12 PM
funracer's Avatar
funracer
Thanks for responses guys/gals. I will be buying the Hannabi's today.
Rgds
barnoun
Sep 17, 2018 05:04 PM
Rgoodwin
Tires, Wheels, & Brakes
Apr 21, 2017 10:56 AM
SosoMINI
Nov 22, 2015 03:17 PM
madmax88
Oct 26, 2015 01:45 PM
Mini'mon
Aug 16, 2015 04:15 PM
