Uneven brake wear
Old Sep 18, 2006 | 07:01 PM
henc's Avatar
henc
Uneven brake wear
I just changed my front brake pads and noticed that I have uneven wear, not on the same wheel as in inner and outer but uneven as in the driver's side was worn down to 1/16" and the passenger side still had 3/8". Is this normal? I have been searching the posts, but I cannot find anyone with the same situation. The inner and outer pads on the front driver's side definitely needed changing, but the front passenger side could have gone longer. Do I have a bad caliper? Another item worth noting is that the car has a slight pull to the left (driver's side). At first I thought I needed an alignment, but now I am not sure.
If the caliper is bad, I have 50K miles on my '02 MCS, so should I consider upgrading the brakes (pads, rotors and calipers)? I just did the pulley, exhaust, unichip and cold air intake, so money is a little low. How much does it cost, any suggestions?
Old Sep 20, 2006 | 10:22 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Some articles to look through for a reason for your uneven pad wear-
http://66.102.7.104/search?q=cache:a...s&ct=clnk&cd=1
or for a PDF try
http://www.mightyautoparts.com/pdf/a...0pad%20wear%22
http://www.forparts.com/ICdiscbrakecalipers6.05.htm
http://www.kitcarbooks.com/brakepads.html
Gremothra
Sep 9, 2015 08:42 PM
Tinklespout
16
Sep 6, 2015 11:39 AM
Sep 4, 2015 09:23 AM
PelicanParts.com
Tires, Wheels & Brakes
Sep 3, 2015 03:22 PM
Sep 3, 2015 02:06 PM
