Why turn rear piston.
Old Aug 14, 2006 | 08:29 AM
Harvchild's Avatar
Harvchild
Does anyone know why the rear brake pistons must be turned while compressing back into caliper and not the front?I,ve never heard of it previous to owning a mini.
Old Aug 14, 2006 | 08:32 AM
toddtce's Avatar
toddtce
Because inside of the piston is a worm screw that is used to apply pressure to the pads when you pull the parking brake. Over time as the pads wear the piston must move and stay out more for this to work. As you yank on the handle and or apply pressure to the caliper this rotates the piston out to keep this distance in check. When you retract the piston back in you are simply winding it back up the shaft to start all over again.
Old Aug 14, 2006 | 08:42 AM
Harvchild's Avatar
Harvchild
Thanks for the fast answer.
Dec 23, 2015 10:36 AM
HCClubbie47
R55 :: Clubman Talk (2008+)
Aug 24, 2015 02:16 PM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
Chippawaguy
Off-Topic :: Autos
Aug 19, 2015 11:30 AM
bctf1
Aug 6, 2015 12:55 PM
