R95 JCW Star Spoke Wheel worth it? rubbing issues? ride?
Old Mar 21, 2006 | 09:35 AM
hexproject's Avatar
hexproject
hi, Thinking about getting the R95 JCW Star Spoke Wheel Set?
Any rubbing issues? and ride quality?
I am looking to replace my run flats with some other tires.. but i heard the JCW are run flats too?any of you have experience with that?
]thanks. Also, major difference between run flats and performance tires? obviously, i want the mini to handle like it should.. if run flats will get in the way.. then run flats got to go
Old Mar 21, 2006 | 09:37 AM
hexproject's Avatar
hexproject
i should mention also, that i got JCW installed from the factory... so that's why i am thinking about JCW rims..
Old Mar 21, 2006 | 11:10 AM
Gabe's Avatar
Gabe
Any rubbing issues?
Minimal and only around the tightest turns at full suspension compression. Nothing worth being concerned over.
and ride quality?
Minimal different between the R95 and any other 17" wheel.
I am looking to replace my run flats with some other tires.. but i heard the JCW are run flats too? any of you have experience with that?
Getting rid of the runflats would make the ride actually get better than 17" wheel with runflats. And at 22lbs the R95s aren't the lightest wheels out there, but they are lighter than most 17" wheels offered by MINI.
In the end if you love the look and the feel of increased ultimate grip, go for it. If you're more concerned about a better ride and are trying to be cost conscious, don't.
Old Mar 21, 2006 | 11:23 AM
JCW Driver's Avatar
JCW Driver
Good comments as usual, Gabe.
hexproject, You'll be stunned that you can run a plus sized wheel and tire combo, with non-run flats and get a better ride than OEM 17" combinations with run-flats.
But it's true.
Do what makes you happy, within engineering reason.
Old Mar 21, 2006 | 11:25 AM
ScuderiaMini's Avatar
ScuderiaMini
x 2
Old Mar 21, 2006 | 02:11 PM
bonz's Avatar
bonz
Go for it. No problems with ride quality even in pothole laden upstate NY( I personally think the ride quality is better with larger R95 even with run flats). My ride has JCW suspension so no rubbing even with full car.
Beauty shot !!!
Dec 23, 2015 10:36 AM
SosoMINI
Nov 22, 2015 03:17 PM
phrza81
Oct 10, 2015 11:37 PM
skippermini
Aug 12, 2015 10:05 PM
