Wheels that fit Stoptech BBK
#26
so u have tried this w/no problems huh? i think i will be goin' w/a 5mm & use longer bolts! have u any idea if there is anybody that makes a hub centric 5mm spacer set, i have had no luck ..... i thought MINI MANIA had some but their photo does not match the description hey show a 5mm havin' hubcentric ring but when i called this is not true~
Originally Posted by badassmini
Strom,
Thanks for the link on the 3mm spacers. I'd like to add that KINESIS K18R with 15mm HR spacers. Probably can go w/ 10mm but no one makes a 10mm that is hubcentric.
Just like to add that if you use a 5mm or less spacer it is not hubcentric and it does not need to be because there enough of the hub exposed to center the wheel for proper wheel fit.
#29
Maybe it depends on what wheel/hub rings you use, but 5mm still leaves room for them to reach the hub. The HR are hubcentric being that they fit the Mini hub perfectly, not that they have a hubcentric extension. The larger ones do though, 10mm and such.
I use 5mm all the way around myself (but I have done a lot of fender modding), but could use the 3mm in the rear for better fender fitment and will in fact get those.
#30
Originally Posted by maxmini
I had a set of 17 Volk LE 37 and they needed over 7 mm to clear a set of Stop Tech's. Looking at them we thought there would be no problem but we were suprised.
Randy
M7 Tuning
Randy
M7 Tuning
#31
really they rub w/jus a 5mm!?!?!? hope mine will clear..well i am settin' height around my wheels so will do what it takes, its all good.
so ur sayin' that the HR rings are able to be used as a hubcentric ring?
cuz i do need to order them for my current wheels b4 i get the spacers cuz the burn outs at sterling BMW/MINI screwed my rings up....they used an impact gun instead of torque wrench..... :impatient so they fuked one or two up i cant set it free.
#32
The reason the 5mm is not is pretty simple; there's not enough material for the counter bore on the back side and still have an extension on the front. Think about it.
The 10mm parts can have both, say 2mm of snout for the wheel and 6mm of counter bore for the factory hub. And have 2mm of meat in the middle.
#33
The 5mm may still let the wheel/tire clear the fenders. I'm using 235s though so I needed to do quite a bit of modding.
Anyway, we are off topic to the thread here. My Rota sub zeros should fit any BBK as they clear my TCE willwod 13" with room to spare.
#34
Originally Posted by benthevegan
Damn, thats disapointting . I was told that these would pretty much fit any bbk. I know the LEs are the same as the TEs but with a polished lip, do you think that maybe the lip pushes the spokes back more? This may mean that the LEs don't fit stoptechs but TEs do, could this be right
Randy
M7 Tuning
#35
#36
#37
yea but cant afford "the wheels" right now!!
:smile: huh, this is what Helix said!! as far as why a 5mm would not werk, but i wanted to make sure theres not a miracle solution.
Originally Posted by toddtce
Bingo! This is the key point I was trying to convey. Having the ring center on the hub is only half of the issue. NOT having the snout of the spacer support the wheel is then a NON hubcentric application. Having the spacer register here only on the factory hub is about worthless. The wheel is what you're after.
#42
#43
#45
Can anyone POSITIVELY confirm that SSR GT7s fit over the Stoptech calipers WITHOUT spacers?
I took NAM's word that my Superleggeras would fit with a 4mm spacer and the wheel is just barely contacting the caliper. Not good.
I have a track event this coming weekend and I need to get this sorted out ASAP!!!!!!!!!! Thanks!
#47
Where did you find 4mm spacers, by the way?
#50
Originally Posted by Strom
Interesting - I use the Superleggeras with 5mm spacers, and there's plenty of room. It seems like 4mm spacers should work, and other people have confirmed that they did. I'll have to find the thread I pulled that information from. Sorry for the confusion!
