SS lines recommendation...
Old Sep 7, 2005 | 12:05 PM
goaljnky's Avatar
goaljnky
I would do the search, but I am at work and need some quick opinions. What is a better SS line? What are the differences? In short, which one should I order?
Old Sep 7, 2005 | 03:28 PM
goaljnky's Avatar
goaljnky
Not to be impatient, but I'd like to order these tonight. Anyone has any advice?
Old Sep 7, 2005 | 09:04 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Some people have found generic cheap SS brakelines vs the durable Goodridge SS brakelines.
http://helix13.com/html/products/pro...ew.php?p=9&h=m
$119 a set of four, note different sets for model years
http://outmotoring.com/braided_stain...ake_lines.html
$119.95 a set of four
Old Sep 7, 2005 | 10:27 PM
goaljnky's Avatar
goaljnky
So, for $8 more, is Goodridge better, or about the same?
Old Sep 8, 2005 | 07:30 AM
toddtce's Avatar
toddtce
Most of these hoses are the same. The differences between the companies is that some suggest a thicker wall of teflon, others a more fine braid of ss.
I've heard pros and cons on all the brands over the years.
My only suggestions are:
1. Fittings are spec for the car and do not use adapter fittings. Adapters ARE fine to use but offer another point of leakage. (also are non DOT compliant in this manner if anyone cares)
2. See if you can spec SS fittings on the hose ends. Nice for the life of the hose but bumps the cost up over the more common zinc finish.
3. See if it has a center support with it so you don't zip tie it in place.
Old Sep 8, 2005 | 09:27 AM
goaljnky's Avatar
goaljnky
So do the Goodridge SS from Tirerack meet the criterea?
Old Sep 8, 2005 | 10:53 AM
neilgj's Avatar
neilgj
FYI, helix13.com has the Goodridge SS lines for $119 (read the description they are not generic - they are Goodridge)
That $8 you don't have to spend. :smile:
gar56
Nov 15, 2016 06:41 AM
Tires, Wheels & Brakes
Oct 1, 2015 08:55 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
krohm
Sep 28, 2015 12:16 PM
EVMini
Sep 28, 2015 10:20 AM
