What does it mean when .... brake wear
Old Apr 13, 2005 | 10:12 AM
onasled's Avatar
onasled
Talking about rear brakes here.
What does it mean when your outside pads wear faster then your inside pads? Anything ?
Old Apr 13, 2005 | 10:21 AM
RedBaronF2001's Avatar
RedBaronF2001
Stuck caliper perhaps? Caliper not *sliding* properly on pins causing the outside pad to stay in contact with the rotor.
Any photos?
Old Apr 13, 2005 | 10:26 AM
RLmini's Avatar
RLmini
Have you changed pads before? Putting new pads on used rotrs that have not been turned can cause a little of this. Is this a drastic difference or just slight? there are also two pins on each caliper that allow it to slide together. Putting a little lube of the pins may help as well.
Old Apr 13, 2005 | 12:32 PM
onasled's Avatar
onasled
Thanks for the thoughts guys. I ordered a set of brass bushings this morning so I'm hopping that this is in fact the problem.
The wear difference is not huge, but visually noticable. One side (of the car) is worse then the other.
Old Apr 13, 2005 | 12:40 PM
Coop d'etat's Avatar
Coop d'etat
This is the way the brakes wear on my civic as well, perhaps it's caliper design? On pad stationary, while one pad does the squeezing? I dont know about the mini's calipers, but with the civics on side gets pushed on by a piston, while the other just stays put. That is what I thought caused my wear differences...
Gremothra
Sep 9, 2015 08:42 PM
Tinklespout
16
Sep 6, 2015 11:39 AM
Sep 4, 2015 09:23 AM
PelicanParts.com
Tires, Wheels & Brakes
Sep 3, 2015 03:22 PM
Sep 3, 2015 02:06 PM
