My new approach to rotating tires...
Old Mar 22, 2005 | 10:54 PM
  #26
911Fan's Avatar
911Fan
Originally Posted by Hammer
By regularly rotating, all the tires wear evenly and last much longer than just leaving them where they are. I usually get at least 40,000 miles out of a set of tires - but again, this is all pre-Mini, pre-autocrossing.
I think you'd be hard pressed to get 40K miles out of your original set of MCS runflats no matter how much you rotated them unless you drive like your Grandmother! The secret to getting even wear is regularly monitoring the tire pressure, assuming things like the alignment and tire balance are in order.
On some sports cars, it's simply impossible to rotate the tires (directional tread + different sizes front to back). And since they're very expensive it pays to carefully monitor tire pressures. Those efforts are usually rewarded with even tire wear, except on certain especially painful cars (tire-wise) like the NSX. I used to own one and I was lucky if I got 8K miles out of each set!
Old Mar 24, 2005 | 01:19 PM
  #27
Hammer's Avatar
Hammer
That's why I wrote "pre-Mini and pre-autocrossing". I'll be happy to get 10,000 miles out of my Azenis.
Old Mar 29, 2005 | 04:59 PM
  #28
Alex@tirerack's Avatar
Alex@tirerack
Originally Posted by minihune
Alex@tirerack.com would say "always" put the newer better tires on the rears. Why? Because in the event of hydroplaning you want the best hydroplane resistant tires on the rear as they follow the fronts which hydroplane less as you steer through the water. This allows the most safety for wet conditions. For dry conditions it isn't as critical unless the amount of wear between fronts and rears is drastically different.
This was also confirmed by Michelin on their Laurens proving ground, with the help of local Carolina black and whites.
I would NOT mix runflat and non runflat.
Alex
Old Mar 29, 2005 | 05:00 PM
  #29
Alex@tirerack
Originally Posted by bdmini
DON'T SKIMP ON YOUR TIRES!!!
Bottom line!
Alex
Island maser
General Discussion
Oct 1, 2015 01:09 PM
Sep 22, 2015 06:59 AM
Car Care Products
Sep 22, 2015 06:47 AM
Sep 22, 2015 06:43 AM
Sep 18, 2015 02:44 PM
