Kosei K-1's with 215/45-17's rubbing issues?
Old Mar 12, 2005 | 08:17 AM
cheiron19's Avatar
cheiron19
I am going to purchase new tires and wheels for my MCS and it looked lke others have already gone with the wider profile tire on these wheels. Any rubbing issues?
Also, has anyone run these on lowered cars?
Which spring set were you using if you are and did you have any rubbing issues?
Thanks!
Old Mar 12, 2005 | 02:46 PM
onasled's Avatar
onasled
I run this combo and my MCS is lowered with H-sports. I've also corrected camber and toe with rear control arms.
I rub like crazy and have had to trim tons of plastic away from the wells along with some grinding of metal. I still rub!
I will have to put a touch more - camber in the rear wheel to hopefully end the rubbing for good.
Now, with that said, understand that not all Minis are the same. I know that Randy Webb has successfully managed to get 235/40/17 on the Mule with the K1s.
When I replace my tires I will most likely go with 40 rather then 45.
Old Mar 14, 2005 | 02:47 PM
Mjolnir's Avatar
Mjolnir
Well, I ran that combo as well as a 215/40-17 with no rubbing.
I also ran 225's on my Kosei's but had rubbing on "hard" bumps.
Old Mar 14, 2005 | 04:52 PM
onasled's Avatar
onasled
Difference might be the profile, hence why I would go with 40s nest time. As I said, seems that not all Minis are from the same mold.
PS. Are you lowered?
Old Mar 14, 2005 | 05:03 PM
minibrute's Avatar
minibrute
I used falken ziex 512 215/45/17 on kosei k1 17x7.5 45 offset with factory springs and had no rubbing or any other issues.
healtoe86
Sep 15, 2020 07:25 PM
rtk90
Aug 29, 2019 09:08 AM
devicemanager
Jun 17, 2016 06:18 PM
tylewis
Sep 6, 2015 01:07 PM
Sep 1, 2015 04:02 PM
