2002 cooper
Old Feb 13, 2005 | 07:38 PM
Crawberri's Avatar
Crawberri
2002 cooper
I Just got a 2002 cooper no S or any mods. I want to put 18in wheels on but after reading all this i dont know it they will work. I dont plan on lowering it but i do want to drive it daily.
Old Feb 14, 2005 | 08:43 AM
Alex@tirerack's Avatar
Alex@tirerack
215/35/18 with an offset 42 or higher!
Alex
Old Feb 14, 2005 | 10:29 AM
Crawberri's Avatar
Crawberri
size
thanks alex.
My tire guys will like that you work for tirerack. They often quet you guys.
what size 18 is that thou. 7 or 7.5
Old Feb 15, 2005 | 09:12 AM
tontobird's Avatar
tontobird
I would absolutely not consider 18" wheels for a daily driver. You are almost guaranteed to have problems unless the roads in your area are in pristine condition. You cannot be careful enough, you will have problems.
Good luck with your Cooper!
Old Feb 15, 2005 | 05:33 PM
BaldBikerGuy's Avatar
BaldBikerGuy
Love my 18"s....
Can't wait to change back over to them when this Ohio winter breaks
Old Feb 16, 2005 | 02:28 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
thanks alex.
18x7" or 18x7.5" are both fine.
215/35-18 tires will fit rims from 7 to 8.5" wide with a perfect fit for 7.5" rims.
While 18" rims look nice, they also tend to be heavy and if light then expensive.
At tirerack.com some examples-
SSR GT1 18x7.5" $259 each 17 pounds et+40mm!
SSR comp 18x7.5 $459 each 14 pounds et+42mm
O.Z. Chrono Evolution 18x7" $219 each 19 pounds et+42mm
O.Z. Superleggera 18x7" $350 each 17.6 pounds et+42mm
Also some less expensive but heavier rims at edgeracing.com
If you are careful and don't hit the potholes and bumps at higher speeds then you might do OK with strong forged wheels and non runflat tires.
For an MC you don't have a lot of power so the heavy wheels are not going to help with acceleration. If you can keep the rim weight under 20 pounds you'd be doing OK.
triple5soul
21
Jul 29, 2016 04:27 AM
Mini'mon
Aug 16, 2015 04:15 PM
Fizzyx
Aug 14, 2015 08:24 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
