How to determine wheel size specs?
Old Jul 20, 2021 | 10:09 AM
jYO's Avatar
jYO
Just purchased a 2022 JCW 2 Door that has 17" wheels. I'm trying to determine what the following measurements are:
  • Diameter
  • Width
  • Offset
I called my local dealer and none of their departments could answer the question which I thought was pretty crazy. Does anyone know how I can get this information so I can potentially buy new rims that will fit?
Old Jul 20, 2021 | 11:14 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
If you have the car in the garage, you can find the wheel specs on the back side of the wheel face. Size should be cast into the wheel, and offset might be stamped or engraved somewhere. Remove the wheel from the car, and have a look!
You should see something like this:
Old Jul 22, 2021 | 07:51 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Bolt Pattern 5x112
Wheel size 17x7" (diam. x width)
Offset 54
Center bore 66.6mm
Thread size M14 x 1.25
Frank Matyja
Mar 26, 2008 07:40 AM
earlrabbit
Tires, Wheels, & Brakes
Apr 24, 2007 08:33 AM
davavd
17
Oct 3, 2006 12:25 PM
s4gerri
Dec 21, 2005 07:57 AM
Grinder
May 20, 2003 11:42 AM
