Will these BBS fit properly and not rub?
Old Jan 3, 2005 | 02:52 PM
r2edline's Avatar
r2edline
Hey guys, I'm looking for wheels for my MCS and I'm just wondering if these will fit properly and not rub:
BBS RX
17 x 7.5
ET35
What do you guys think? Probably run 205/45/17 sized tires on them. Any comments would be great. Thx
Old Jan 3, 2005 | 05:35 PM
Ryephile's Avatar
Ryephile
Very aggressive offset, I'd venture to say it'll rub alot unless you have lots of negative camber.
Old Jan 3, 2005 | 08:53 PM
kenchan's Avatar
kenchan
Yes, very very very tight fit with 205/45/17. It *might* work without dremelling if you used ParadaSpec2's or SP9000's...but I wouldn't do it
unless you're planning to trim a little off the fenders.
Alex at tirerack had how-to's, I think, on where and how to dremel.
Old Jan 4, 2005 | 08:24 AM
r2edline's Avatar
r2edline
Nah, I'm not going to bother then. I don't want to have to deal with all that. Thanks for the help.
Old Jan 4, 2005 | 10:48 AM
Alex@tirerack's Avatar
Alex@tirerack
Dremel time - its about the 2.30 position on your driver's rear fender- and the same position on the passenger side. Its a long rectangle bracket. you remove the 90 degree angle on the lower inside of this bracket with a dremel medium sanding drum - sand to a soft 45 degree angle - prevents rub on travel, and as Ryan mesions negative camber helps. et 35 is Miata agressive.
Alex
W0TM8
Dec 19, 2019 07:50 AM
devicemanager
Jun 17, 2016 06:18 PM
bjcarter2
Aug 31, 2015 04:03 PM
Aug 12, 2015 01:24 PM
