Tire with on a r53
Old Nov 26, 2017 | 12:01 PM
50ina30's Avatar
50ina30
Tire with on a r53
hey guys and gals, Ive got a 2003 MCS that i want to put wider rubber on this summer. currently Ive got 205/55/16 on some OZ ultraleggeras (16x7). just want to know if anybody has had issues with fitment going up to like a 225?
Old Nov 26, 2017 | 01:27 PM
MINIAC's Avatar
MINIAC
To get any choice in tires you'd have to go 225/50-16 which is going to put the tire 10mm closer to the wheel well trim ... and might rub with an ET37 wheel.
Taller tires like 205/55-16 and 225/50-16 adversely effect acceleration. Normal plus size for 195/55-16 is 205/50-16. There are few tire choices in 215/50-16 and 225/45-16 plus sizes.
Old Dec 9, 2017 | 01:41 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
If your 16x7 wheels are rubbing on the inner suspension then you can get more clearance by using a wheel spacer. But spacers may require longer wheel studs or bolts. You want to have enough threads to secure the wheel.
For a given wheel 205/55-16 and 225/50-16 are both 24.9" tire diameter.
225/50-16 fits rims 6-8" wide, perfect for 7" wide rim so it will fit your current rim. 16x8" will require more aggressive wheel offset and poke out
Compared to OZ Ultraleggera 16x7 et 37
16x8 et24 gives about the same inner clearance but pokes out 25.7mm more
Using this offset would require a wheel spacer for clearance to the inner suspension.
16x8" wheels with 225/50-16 tires might look aggressive but clearance would be much reduced due to any suspension drop from using coilovers. You may need more negative camber (adjustable front camber plates and rear adjustable control arms) and adjust ride height for minimal clearance.
