225/17/45 fit on R52 JCW?
Old 12-05-2016, 08:07 PM
burley's Avatar
burley
burley is offline
Title is wrong, cant edit. Meant 225/45/17. You folks are smart, you'll figure it out.
I've already done the searching and I get a lot of speculation on both sides with very little first hand experience.
Has anyone actually tried to get 225/45/17 to fit on a JCW or a regular R53/2? I think the JCW has 10mm difference in height.
I bought some R90's on craigslist for $400, which come with Blizzaks with 60% tread. I didn't realize they came off an R56, not R53, so I didn't even bother with checking the tire size.
I dont have my R52 JCW yet, picking it up in a couple weeks so I cant check. I guess worst case scenario I can just sell the tires, its a somewhat common size.
Old 12-05-2016, 09:05 PM
Fly'n Brick's Avatar
Fly'n Brick
Fly'n Brick is offline
My R52 with stock R98 web spoke wheels wears 205/45/17. According to the 2006 Motoring Accessories workbook, that is the tire all 10 of the 17 inch factory wheels are spec'd at. The 16" wheels call for 195/55/16 and the 15" 175/65/15. Hope this helps.
Also hope you enjoy your new to you drop head. After all, topless motoring is motoring at it's best.
Old 12-09-2016, 09:31 AM
Dr. Spade's Avatar
Dr. Spade
Dr. Spade is offline
They will likely rub your inner fender lining at full lock turns. Doubt it would run the outers. Just try them on, you already have them.
Old 12-09-2016, 06:26 PM
Bernard Barbour's Avatar
Bernard Barbour
Bernard Barbour is offline
I'm running 225/40/18's on factory R95 wheels. I bought it this way. I did notice the other day that there was a small rub spot on my inner fender wheel well. I've been driving the car for a month but have not heard it rub.
Old 12-09-2016, 09:47 PM
burley's Avatar
burley
burley is offline
Good looking Cooper. I just bought the same Chili Red JCW with the same R95 wheels, except mines an R52.
Looks like I'll have an extra 1/2" of sidewall than you, but the same height/width overall. If you're having minor rubbing I can live with that. Thanks so much!
Old 12-10-2016, 06:05 AM
roadrunner255's Avatar
roadrunner255
roadrunner255 is offline
Anyone running the 225/45-17 on a GP2? Currently have the stock Kumo 215/40-17'. No winter driving. Cheers
Old 12-11-2016, 06:03 AM
burley's Avatar
burley
burley is offline
@bernard: what suspension are you running?
Old 12-11-2016, 07:53 AM
roadrunner255
thanks
Old 12-12-2016, 06:35 AM
Bernard Barbour
Burley, I have the stock JCW suspension.
Old 12-12-2016, 07:13 PM
burley's Avatar
burley
burley is offline
Perfect, that's what I'll have.
Old 12-26-2016, 07:40 AM
eastcoast60's Avatar
eastcoast60
eastcoast60 is offline
I have those exact tires on S-lites on a 2006 R53 with Tein springs and it doesn't rub anywhere.
Old 01-10-2017, 04:40 PM
burley's Avatar
burley
burley is offline
Finally purchased my JCW.. after I took a closer look I realized it doesn't have the JCW BBK, but Brembo brakes. Any idea if these are close in size? Now I'm just hoping any 17" wheels will fit over these oversized brakes. They sure do look cool though with the drilled rotors.
Im still waiting on the right moment to pick up the wheels/tires in question.
